Question NETGEAR A6100 Adapter won't connect to 5ghz Wifi
May 28, 2019
I'm using a netgear a6100 dual band wireless adapter since my quelcom atheros internal wic doesnt support 5ghz.. everytime i connect its doing it at 2.4.. can't figure out how to force it to 5ghz
It is.. i got it working after calling netgear. You have to use the netgear genie to connect, the standard windows wifi connector doesnt show both signals(put off by the xfinity modem) genie is needed to choose 2.4 or 5ghz.
