G
Guest
Guest
Archived from groups: (More info?)
I am running Windows XP Pro SP1a with three accounts. One of them is
an Administrator account and the other two are Power Users. The issue
I'm having is specifically with using WPA encryption though a similiar
issue is also occuring with WEP.
Using the Netgear Configuration Utility under the Administrator
account, it works fine. If I then go and log into one of the other
accounts, I can not select that profile even though it is saved. I
can not save a new entry as well on these other accounts, so I either
have to configure it everytime I want to use it on them and Apply, or
try using the Wireless Zero Configuration Utility.
Using the Wireless Zero Configuration Utility, works until I reboot
with WPA. I have the Microsoft HotFix: Q815485 applied, so WPA-PSK
with TKIP is an option. Again this works until I reboot, then when I
login I see the Netgear Utility blinking green/red. It will lock into
a connection for a few seconds and then scan other channels again. I
have tried using 128Bit WEP encryption on the router as well and the
Wireless Zero Configuration Utility, and the issue is slightly
different. It takes a while for the connection to be establish, then
it reports it can no get an IP address from the router.
What is the best way to get around this? Is there a user group
besides Administrators in Windows XP I can add these two other users
to so they can access the profile created by the Administrator in the
Netgear Utility?
Currently, I am just using a Wireless MAC filter to only allow those
wireless devices that I know of to connect to the router, but I would
prefer to have atleast some sort of encryption on. Any help would be
most appreciated.
-Rob
Netgear Utility?
most appreciated.
-Rob
