NetMeeting Video/Audio problem with MN-820
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
Hi gurus,
Anyone any ideas how I can configure my MN-820 base station to allow
incoming video/audio stream
for NetMeeting? Interestingly, the remote user can see/hear me, but I can't
see hear them....
I've already looked at the MS Knowledge Base, and found an article
describing the ports used by NetMeeting.
So, I enabled app-triggered port replication for NetMeeting (TCP trigger
types are all TCP - according to the article,
the UDP ones are dynamically assigned) on the following:
389, 522, 1503, 1720, 1731
But still no joy.
I know its related to the MN-820 as I hooked my PC directly to the broadband
router
and video/audio worked just fine....any ideas out there?
Thanks in advance...
Karl
How did you set the ports?
On one hand, you need to set the trigger ports to open
themselves (same port on all four cases of a line), as many
lines as ports... and on another hand you need to pick a
trigger port to open a range of potential UDP ports -- the
trigger port is on the left two boxes, and the UDP range on
the right two boxes.
You can run Command Prompt and enter netstat -ano while
running NetMeeting. It shows a list of all ports and
associated processes, so you can get an idea of which UDP
ports NetMeeting opens.
>-----Original Message-----
>Hi gurus,
station to allow
>see hear them....
article
>But still no joy.
>router
>Karl
Thanks for the advice....watch this space!
Surprised no-one else has run into this one...even more surprised Microsoft
hasn't published the required port settings ....
"lilo" <anonymous@discussions.microsoft.com> wrote in message
news:2c61801c468c8$73bcfdd0$a301280a@phx.gbl...
> >Hi gurus,
> station to allow
> >see hear them....
> article
> >But still no joy.
> >router
> >Karl
So did it solve your problem?? I am having the same issue
open the ports and still no luck.
How exactly did you solve it?
Thanks
Rafa
surprised Microsoft
message
many
the
range on
UDP
>> >Hi gurus,
>> station to allow
>> >see hear them....
found an
>> article
following:
>> >But still no joy.
>> >router
there?
>> >Karl
Karl Soar wrote:
> Hi gurus,
> I can't see hear them....
That is the normal symptom for H.323 audio/video. Generally the only
solution is to designate the NetMeeting computer as the dmz machine. Make
sure it is running a software firewall ( which may need configuration for
NetMeeting).
> trigger types are all TCP - according to the article,
Actually 1503 and 1720 are the only tcp ports that matter incoming. but udp
ports 1024-65535 could be allocated dynamically for audio/video
transmission.
> But still no joy.
> broadband router
The dmz solution is generally the easiest. It is theoretically possible to
use application triggered port forwarding but the complications are often
insurmountable.
Brian Sullivan
Meeting by Wire ( http://www.meetingbywire.com)
Is your PC protected? --
http://www.microsoft.com/security/protect/default.asp
Sorry for the dealy in getting back to you.
Unfortunately, it didn't...just can't seem to get the hard facts on how to
enable triggering for port forwarding the
dynamic UDP ports. In the end, I switched to Windows Messenger (the person
I comunicate with fortunately
uses XP too... and this works just fine via the MN700...
Very annoying.
Karl
"Rafa Ballesteros" <rafael_ballesteros_bono@microsoft.com> wrote in message
news:2fa1a01c46d10$7acbd6e0$a301280a@phx.gbl...
> Thanks
> Rafa
> surprised Microsoft
Put the computer in the DMZ to use that old piece of software.
> Very annoying.
> Karl
>>Thanks
>>Rafa
>>surprised Microsoft
