Network adapter issue
Liam_39
Commendable
Sep 6, 2016
6
Hi everyone in having a problem with the wireless adapter. Sometimes it stop working and it cant find any network or i have a limited connection Aldo if the WiFi is working on my phone. Pls help
I would try a new card then.. when you say TP-Link 300Mbps is that a USB wifi card? if so try a few different USB ports.. if its not one pickup a cheap adapter and try that (if you can't borrow one) and see if it solves your issue.. OR if non of that works and you are sure other PCs work normally when connected reinstall windows.
When you connect the computer via ethernet cable to your router does it all work ok?
Have you tried the adaptor in a different pc?
Is your os windows? So the os recognises the device - does it offer any trouble shooting / setup steps?
