Hi all,
I have a Asus NVidia GeForce GT 730, but it won't fit onto my motherboard due to my network card. I have come up with possible solutions - and their drawbacks - but I'm not sure which one is the best:
1. Use a PCI x1 riser. I can use this to relocate my network card, so the graphics card can fit. Drawback: Where do I place the network card, where it can be supported from the bottom, not just by the screw?
2. Use a PCI x16 riser. I can use this to relocate my graphics card. Drawback: Screw isn't enough to support weight of graphics card.
3. Remove the network card, and use a USB Wi-Fi dongle. Drawback: Wi-Fi reliability and strength.
3.5. Remove the network card, and use an Ethernet cable. Drawback: Is impossible in the current setup I have.
4. Upgrade my motherboard from mATX to ATX. Drawback: Is impossible due to budget.
If any money needs to be spent, my budget is £10.
I will not mod my case.
Thanks!
Thanks!
