Network card or usb wireless?
yocheco619
59
Heres the thing, I have a netgear router in one room with a pc there and in the other i have my pc i just built. I want to connect it on my network and am wondering whats the best way to do it aside from being wired? Also, what does whatever you suggest compatible with?
G
Guest
Guest
If you just built a PC you'll be comfortable installing a PCI wireless adapter -- that's generally the best choice for a desktop.
lyleb
342
