network card teaming help
First you need a switch that support this also.
Then your pc must have the support. Microsoft does not support it natively in all versions of windows so many times you need special nic drivers that can do this.
In the simplest case you run LACP and it will just work. Otherwise you set the bonding manually on both ends.
