G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
have 2 XP PC's.
They are connected via a switch.
The PC's can ping each other.
I have ICS setup & the client PC can connect to the Internet OK
I can't however map drives or use remote desktop.
They have matching usernames & passwords.
They aslo have F&P sharing setup
I have also disabled the firewalls to see if that helps
It doesn't.
Can anyone suggest anything else?
Thanks
have 2 XP PC's.
It doesn't.
Thanks
