Network manager startup problem/freeze
ViperX45
4
Hey!
I'll get straight to the point,
Randomly, on start-up, my internet browsers and networks do not work properly if at all. The things I notice is:
It's always on system start-up
Network manager icon on right side of task bar freezes with "loading" icon
No error messages
Unable to access network manager
Unable to access network adapters control panel
Unable to use internet browsers
Sometimes it will fix fix itself after a long time, but I usually just do a restart and that works
Closing firefox, steam, and other useless services in task manager during problem does not help
disconnecting the LAN cable does not help
sometimes non-internet programs will fail to start during problem.
Quick specs:
win 7 64 bit
4GB Ram
Intel core 2 quad 2.66GHz
Nvidia GTX 260
NOD32 Antivirus installed [up to date]
I'll provide more info if you need it
Thanks to anyone who can help in advance
yes i can, I'll go ahead and give that a shot
Also removed "steam" start-up with windows. This is the only app I can think of in the start-up que that can cause the problem
