G goldmunds Feb 4, 2020 13 2 15 Jul 29, 2020 #1 So i just installed android on a hdd and ran it in a pc. Everything is fine, but it cant connect to my ethernet network. What should i do?
Solution Ralston18 Jul 29, 2020 More information needed: What error messages or pop up windows, if any, do you see? Are other network devices connecting correctly? And do so when using the same ethernet cable and router LAN port? Double check your Android's network configuration settings: https://www.wirelesshack.org/how-to-connect-a-android-to-wired-ethernet-connection.html
Ralston18 Titan Moderator Oct 11, 2014 39,128 4,302 146,290 Jul 29, 2020 Solution #2 More information needed: What error messages or pop up windows, if any, do you see? Are other network devices connecting correctly? And do so when using the same ethernet cable and router LAN port? Double check your Android's network configuration settings: https://www.wirelesshack.org/how-to-connect-a-android-to-wired-ethernet-connection.html Upvote 0 Downvote Solution
G goldmunds Feb 4, 2020 13 2 15 Jul 30, 2020 #3 Hey! In Android, no messages pop up. Everything is fine. The lan cable is fine, its all working on windows. Thanks! Gonna double check. Upvote 0 Downvote
