Hello,
I have a problem with a HP Officejet Pro X476dw MFP - while I am at the stage when I need to install the printer, the installation keeps saying "Installing network printer..." and does this for around 5 minuntes. After that, the installation says "Unsuccessful Network Installation" every time. It does the same problem when I install the prniter via ethernet cable as well as wireless.
A fix would be very much needed, I also tried reinstalling the driver, rebooting the computer. Thank you in advance
