I've had some networking problems recently. (It's been 2 months now) . I have 8mbs downlaod and 0.6 upload. I live at my dad's house and my brother frequently watches HD videos or livestreams. So it uses quite some internet. At first, I thought that was the problem but I figured out it wasnt. because when he's watching videos. My ping sometimes goes up to 140ms. But when I'm getting the problems. I'm going alwasy over 1000 ping for a certain amount of time (atleast 1 min, to maybe 10min)
So I thought the problem was my router. The other one was like 7 years old and I got thought that we ahve to change it every 2 year or so. So I bought a Netgear WNR2000-100NAS Wireless Router N300 ( https://www.amazon.ca/gp/your-account/order-history/ref=oh_aui_menu_date?ie=UTF8&orderFilter=months-6 ) When I received it and I installed it. I realized that I had an extra kind of router or more internet port provider. It's easier to understand with that picture.
I can'T tell if my pc is connected from the yellow thing on the image or directly from the router. (because my dad put all the cables in the suspended ceiling and I can't find where it'S going because of the isolation.
As you can see, the modem is plugged from the wall, then 1 cable (internet cables that are actually blue and 1 yellow,) are going in the router. Then out of the 4 ports that can have ethernnet cables, 1 of them is plugged into that yellow thing. The brand name of that thing is DLink DGS-1005g. I guess it's called a desktop switch as I read. I have no clue since when I have that thing and I think our internet provider installed it because we needed more cables. But now that my brother is no more home,. I think we don'T need it anymore.
Here's my problem in brief,
I want to know. Is it the desktop switch(If that's how you call it) that is causing the problem or my internet provider is bad. Also I never got the opportunity to finish a pingtest when I was getting the 1800 ping problem because It was taking ages for the test to find the best server and because it was taking a long time my internet ahd time to come back to normal then I was not getting the wanted results of my hihg ping. :/
Hope you guys can help me, thanks 😀
PC SETTINGS :
EDIT: Could it be my blue ethernet cable the problem? Because I realised there isn'T the little clip on it that lets it stay in place. So if i barely pull on it it goes out.
PC SETTINGS :
OS : Windows 8.1 OEM 64 bit
Motherboard :ASRock Z97M Anniversary Micro ATX LGA1150 Motherboard
CPU : Intel Core i5-4590 3.3GHz Quad-Core Processor
GPU : Sapphire Radeon R9 280X 3GB Dual-X Video Card
Memory : G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory
SSD : Crucial M500 120GB 2.5" Solid State Drive
HDD : Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Power Supply : Corsair Builder 600W 80+ Bronze Certified ATX Power Supply
