Question Network Speed issues.
Mar 3, 2019
I have two desktops both connected to the same gateway via Ethernet. They receive different connection speeds. One receives roughly 10% of the speed the other does. Is there anything I can do to fix this?
The gateway is a Calix Gigacenter 844g.
The computer with the connection issue has an MSI A320M PRO-VH mother board, a Ryzen 5 1600 CPU. Any ifo on this problem with be amazing help, thank you.
Ethernet drivers installed for your motherboard?
https://www.realtek.com/en/componen...0-1000m-gigabit-ethernet-pci-express-software
Which connection speed do you get on the MSI A320m? 10Mbit, 100Mbit or 1Gbit?
View: https://i.stack.imgur.com/ePrl6.png
Did you try a different ethernet cable?
Try a different LAN port of the Calix
Eventually a BIOS update of the MSI can help. Use the tool/menu "M-FLASH" inside the BIOS itself. Download the BIOS and unzip it to the root directory of a pen drive and use M-Flash.
How to video:
BIOS file:
Be sure it´s the A320M-PRO-VH-PLUS:
https://us.msi.com/Motherboard/support/A320M-PRO-VH-PLUS#down-bios
Latest posts
