I built my PC back in 2020 or so and it has been relatively no problem until very recently when I've been getting download speeds of 3 Mbps (yes, bits not bytes). It is plugged in with a wired ethernet connection and all the other devices are getting 90+ Mbps at a bare minimum.
I've got an Asus Rog Strix B550-E gaming wifi motherboard.
I've tested the wifi connection also and it's equally as bad as the wired connection. I've tried resetting the network adaptor settings, I've ensured all the drivers are up to date, I've turned off the windows auto tuning level, I've checked for malware, I've even reset my entire machine, wiped it more than once and it still is presenting the same problem. I tried pinging 8.8.8.8 and it's return is 600+ms usually.
What am I missing? Is it a hardware problem perhaps? I've heard that there are some issues with the ROG B550 series motherboards, could that be the issue?
