Hi There,
This is my first time posting. We have a property that was setup with Ethernet cables in approximately 1998-1999. Since then, all the wires have been enclosed by sheetrock, etc. and I actually have no idea specifically where each wire is in what part of the wall, etc. That being said, I was told on another forum that our network setup was "bad" and that I should update/fix it, but wasn't given a lot of advice on suggested hardware models and what really should be "fixed" other than maybe try to run more cables everywhere (which really isn't too much of an option).
ALL wireless routers, switches, etc. (except for "main switch"), I estimate are probably at least 8-10 years old. I'd like to show a diagram I made up quickly that shows you how the network is setup, but since this is my first time posting here, I'm not sure how to attach/upload my file? If someone could tell me that quickly, then I can post a picture = to a thousand words!
What I'm hoping for is constructive, easy to follow suggestions about how to make the network stronger/safer, easier to "manage" (for a person with limited tech skills). I'd LOVE to know what wireless routers (brand, model, etc.) and what network switches (brand, model, etc.) you think I should buy to start replacing some of these "dinosaurs.) And/or if you think that's even necessary. The "MAIN" switch has 7 ethernet cords plugged into it and is a netgear fs116.
I'd ALSO like to get at least one or two external hard drives onto the "network" so they can be accessed from any one of the 3 buildings. I currently have a Toshiba 2TB usb connected external hard drive, but no "hardware" that I can plug it into so right now it's just a backup for one of the pc's on the property.
http://
http://
