Interesting problem here: I just moved into a townhome that is wired for fiber. Each room has 2 ethernet jacks (one presumably for voice as it does not work for internet?) and a coax jack. I turned on my computer, and in addition to my own devices, I saw all of my neighbors devices as well (30+ others).
Ideally, I would like to set up my own network or homegroup so I can only see the devices I own. The problem is, wifi is not going to work due to thick walls (low signal) and bandwidth needs.
If I limit myself to one device per room, I can make a homegroup, but this is inconvenient. I would like to have the following setup:
Living Room:
1 HTPC
1 xbox (used as media center extender)
1 router for wifi (guests, as well as smartphones, ipad & tablets)
Office:
2 PCs
1 xbox (media center extender)
In a perfect world, these would all be on the same network. I have at my disposal one ethernet switch (5 port), and a standard d-link router. If I have one device in the wall, I cannot seem to get it on the same homegroup as a device on the router via wifi. Is there a more efficient way of achieving a home network?
Living Room:
1 HTPC
Office:
2 PCs
