Networking errors (authentication connection)
SugarPsycho
215
I am trying to connect to several games (so far these are minecraft (only the servers singleplayer works), warframe, war thunder, and uplay.) most games are seeming to have issues connecting to the authentication server. So far I have, restarted my pc, reinstalled most of the games, restarted my router, checked my ports, checked my firewall, flushed my dns, and checked other forums online but they were only specific to one game. I have also tested the games on other pc's that share my network and I have also been able to run other games, (playerunknowns battlegrounds, heroes and generals, paragon, world of warships and most EA games.) I also suspect that it may be causing issues with Battlefront II multiplayer beta. Does anyone have a solution?
EDIT: I also traced my route to a minecraft server (only did it with minecraft) and I could connect to it over CLI but not through the game.
Shotgun surgery. Re-installing will fix things, but issues like this could have been fixed with a little more patience. Although I am prone to re-installing myself as I feel it is the best overall way to get a PC which has been running a while back to perfection.
I have my pc's firewall off and I turned it back on with failure still, my network firewall is allowing my families computers to connect to the same things I am trying to connect to however.
If other PCs at the same location do not have this error and yours does. Play that Sesame Street game.... one of these things is not like the others, one of these things is not quite the same.
Go to the other PC and go through their network settings and firewall settings.
Do the same on your own.
Check your homes firewall in case a port is not open but forwarding traffic to that other PC.
I was tired of the issue it was causing a lot of irritation.
