Networking problems after XP Pro re-installation
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I have one Win XP Pro system which connects directly to the internet via
a USB ADSL modem. In another room I have a Win ME system that I need to
give internet access to, and I also need to share folders between each
system. They are both connected to a Netgear DS106 hub. Since
upgrading and re-installing XP Pro I can not seem to get these two
systems to even see each other.
The Netgear DS106 has both connections lit up as *connected at 100Mbps*.
I completed the networking wizard on the XP Pro system and ran the
disk on the ME system. I've been told to *enable NetBIOS over TCP/IP*
on the XP Pro system, which I've done. The same seems to be enabled on
the Win ME system, as the relevant box is ticked and greyed-out.
Both systems are on *MSHOME*, but they both only list themselves in the
workgroup.
When I start the ME system up, I can see connection attempts on my XP
Pro system in the new Nvidia Network Access Manager log, but adding the
stated IP address to the *allowed* list does nothing, and it is still
logging blocked connection attempts from said IP address.
I can see nothing in the Windows Firewall settings that I am supposed to
change.
Can anyone advise on where I'm going wrong?
Dial-Up Networking Connections Do Not Work After Upgrade to Windows XP:
http://support.microsoft.com/default.aspx?scid=kb;en-us;303488&Product=winxp
Q320558 - Dial-up Modem or PPPoE Option in New Connection Wizard Is Unavailable:
http://support.microsoft.com/default.aspx?scid=KB;EN-US;q320558
Mark L. Ferguson
FAQ for Windows Antispy http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
"Cuzman" <cuzNOSPAM@supanet.com> wrote in message news:df4ktj$bcn$1@news.freedom2surf.net...
> I have one Win XP Pro system which connects directly to the internet via a USB ADSL modem. In another room I have a Win ME system
> that I need to give internet access to, and I also need to share folders between each system. They are both connected to a
> Netgear DS106 hub. Since upgrading and re-installing XP Pro I can not seem to get these two systems to even see each other.
> The Netgear DS106 has both connections lit up as *connected at 100Mbps*. I completed the networking wizard on the XP Pro system
> and ran the disk on the ME system. I've been told to *enable NetBIOS over TCP/IP* on the XP Pro system, which I've done. The
> same seems to be enabled on the Win ME system, as the relevant box is ticked and greyed-out.
> Both systems are on *MSHOME*, but they both only list themselves in the workgroup.
> When I start the ME system up, I can see connection attempts on my XP Pro system in the new Nvidia Network Access Manager log, but
> adding the stated IP address to the *allowed* list does nothing, and it is still logging blocked connection attempts from said IP
> address.
> I can see nothing in the Windows Firewall settings that I am supposed to change.
Mark L. Ferguson wrote:
" Dial-Up Networking Connections Do Not Work After Upgrade to Windows XP:
Unavailable:
http://support.microsoft.com/default.aspx?scid=KB;EN-US;q320558 "
I appreciate your time, butthese fixes have nothing to do with my
problem. I have neither upgraded a Win ME system to XP, nor do I have
problems connecting the XP system to the internet.
