Networking Problems (WIFI)
jaynbay112
14
So here's my story, I have Internet Speeds at 30 down and 10 up. When plugged in via Ethernet, I get those speeds as expected. With WEP WiFi (not my decision, haha) and a semi decent Belkin N Router, I can expect around 17 down and 7 up, usable for most applications. However, recently in my room and the story below, I've been experiencing severe spikes, no clue why. Those spikes ranged from low speeds to total dropout's (only downstairs). I'm quite a heavy Internet user and would like to solve this issue, for a more clear map, look below.
Attic - ROUTER
2nd Floors, 4 Rooms, furthest room has connectivity issues to my knowledge
___________________________________________________
1st Floor, Problems connecting Wifi from Xbox One in living Room and Tablet Experiences SLOW Speeds
Basement, no verdict
So my question to you, is how can I resolve this issue, please leave getting new router/modem out of the question as that won't be happeing anytime soon (again, not my wifi)
I've come up with the following, Wifi Extenders/Boosters, no opinion/knowledge
PLC (power line comm), would like to fix, but seems pricier and always requires wired connections
Thanks a lot!
Just buy a power line to wireless extender.
Attach Ethernet to one of the four ports of the router.
Use the other power line in room or socket in house where desired.
Can be used via an Ethernet cable or as a wi-fi range extender.
Very good indeed for where you get a poor signal or spikes/ lag.
Its the range that cause the lag. Plus crossover from other routers on the same broadcast band.
2.4Ghz is very cluttered. 5Gh is better if you have a wi-fi device or adapter able to to 300 N.
TRENDnet TPL-410APK - Wireless Range Extender Powerline Kit
Create a wireless network in an area with little to no wireless coverage
Combination Powerline and Wireless N
Connect a smart TV, gaming console, or media player to the two Ethernet ports...
Is the router designed to be broadcasting from up high? A lot of routers have really crappy transmission profiles below them due to their antenna design.
Other questions: Are you on 2.4 GHz, 5 GHz, or mixed? Have you recently installed any new microwaves or cordless phones, or other devices which emit radiation in the microwave/radio bands that could be interfering with your reception? How long have you been experiencing the issue?
Probably not, solely on 2.4ghz acording to inssider and 2, 12 000 btu air conditioner units have been installed 2 months ago and only recently have I noticed issues.
I have an old house, like 1930, while the fuses and all are recent, the wiring, especially in some rooms are not exactly, up to code, would this provide any issue? My room is only getting electricity from a thin copper wire from another circuit, that if I overload with power, would most likely smell burnt.
