Assuming that the Linksys has enough performance and features to work as your main router, you should be able to use it as such, and connect the Netgear to is just as a wireless access point serving your wireless clients.
To configure it as an access point, you would manually assign the Netgear an IP compatible with the main router (outside of the main router's DHCP range in order to avoid a conflict), use a LAN connection to connect it to the main router (as the Netgear won't be functioning as a router, you shouldn't use its WAN port), and disable its DHCP.
If you can't use the Linksys as the main router, then I guess you could use it as an overpriced switch -- connecting it to the Netgear using a LAN port, disabling the Linksys DHCP, and connecting other comptures to its remaining LAN ports.
But if you're going to use the Linksys just as an overpriced switch, you'd probably be better off selling it, and getting an inexpensive forward-looking gigabit switch.
Unless you have a specific need for it, you should generally avoid double-NAT / firewall configurations such that one router connects its WAN port to the other router's LAN port, as this makes communicating between computers on the different sides of the second router more difficult.
