New 144hz monitor not running 144hz issue
Jellso
28
Hello internet
My new monitor (AOC G2460FQ) can only run at 120hz at the moment, while I'm sure it can run 144hz. When i first installed it the image was not well scaled (I had black bars at the sides) so i used Catalyst (I have a AMD HD 7970 graphicscard) to scale it properly. Now however, the maximum refresh rate is just 120hz. I've tried using a program called CRU to make my own custom resolution but this doesn't seem to work (the 144hz option does not appear at the screen resolution options). So I Googled if HDMI can output 144hz and some sources say it doesn't, and some say it does and now I'm not sure if i should buy a mini display cord to solve this issue, does anyone know how i can make my monitor run 144hz?
Thanks in advance
Yes they do. That will work fine as long as you have the Display Port cable 😀
Umm i do have 2 empty mini display ports, does that support 144hz?
Okay thanks 😀
