[SOLVED] New 3090 build! (Need help with compatibility and parts I should change/upgrade)
YoIAmDashing
Respectable
Jun 9, 2021
133
12
2,245
Hi! I finished my build after a lot of research I want to makes sure all of my components are good and If I should change or upgrade components. (Btw I don’t care about the aesthetics compared to the performance of the build)
Here is my build!:
ssd: SAMSUNG 980 PRO 2TB ($429.99)
https://www.dell.com/en-us/shop/sam...C-Oif4gVMmcjh6jxPqA5sRsNKTBvmp10OyvH-sDGHrfbH
cpu: AMD Ryzen 5900X ($549)
https://www.bestbuy.com/site/amd-ry...cessor-without-cooler/6438942.p?skuId=6438942
ram: Crucial Ballistix 3600 cl16 32 GB ($187.99)
https://www.newegg.com/ballistix-32gb-288-pin-ddr4-sdram/p/N82E16820164174?item=N82E16820164174&source=googleshopping&nm_mc=knc-googleadwords-mobile&cm_mmc=knc-googleadwords-mobile-_-pla-_-memory+(desktop+memory)-_-N82E16820164174&gclid=EAIaIQobChMI2PjGipua8QIVkhh9Ch05HgnvEAQYAiABEgJXPPD_BwE&gclsrc=aw.ds
case: Lian li dynamic o11 tower XL ($229.99)
https://www.newegg.com/black-lian-li-o11-dynamic-e-atx-full-tower-case/p/2AM-000Z-00048?item=2AM-000Z-00048&source=googleshopping&nm_mc=knc-googleadwords-mobile&cm_mmc=knc-googleadwords-mobile-_-pla-_-cases+(computer+cases+-+atx+form)-_-2AM-000Z-00048&gclid=EAIaIQobChMIl-LtwLWa8QIVsSCtBh3PhQIIEAQYAiABEgLldvD_BwE&gclsrc=aw.ds
CPU cooler: Noctua NH-D15 chromax.black ($109.95)
https://www.newegg.com/noctua-nh-d15-chromax-black/p/13C-0005-001H5
mobo: ASUS ROG Crosshair VIII Dark Hero ($449)
https://store.asus.com/us/item/202102AM100000007/ASUS+ROG+Crosshair+VIII+Dark+Hero+AMD+AM4+Zen+3+Ryzen+5000+&+3rd+Gen+Ryzen+ATX+Gaming+Motherboard+(PCIe+4.0,+14+2+TI+Power+Stages,+Passive+PCH+Heatsink,++WiFi+6,+2.5+Gbps+LAN,+USB+3.2+Gen+2+Type-C?gclid=EAIaIQobChMImLbr0bea8QIV2wytBh2hGgCJEAQYBCABEgLqYfD_BwE
Monitor: AW2721D dark side of the moon. ($824 but normally on sale for 730 ish)
https://www.dell.com/en-us/shop/ali...21d/apd/210-axsw/monitors-monitor-accessories
psu: seasonic prime titanium 850w ($241.99)
https://www.newegg.com/seasonic-pri...VEz2tBh2cxwFeEAQYASABEgKKNfD_BwE&gclsrc=aw.ds
fans: Noctua NF-A12x15 FLX (10 of them) ($21.95 each $219.50 for 10)
https://www.newegg.com/noctua-nf-a12x15-flx-case-fan/p/1YF-000T-00090?item=9SIAADY5SE4696&nm_mc=AFC-RAN-COM&cm_mmc=AFC-RAN-COM&utm_medium=affiliates&utm_source=afc-Future+Publishing+Ltd&AFFID=2294204&AFFNAME=Future+Publishing+Ltd&ACRID=18786917842&ASUBID=pcg-us-3371640026063771600&ASID=https://www.pcgamer.com/best-pc-fans/&ranMID=44583&ranEAID=2294204&ranSiteID=kXQk6.ivFEQ-BROHUQrVAGhjOTv2UOCODQ
Gpu: FE 3090 ($1499.99
https://www.bestbuy.com/site/nvidia...rd-titanium-and-black/6429434.p?skuId=6429434
Phaaze88
Ambassador
1)O11 Dynamic + NH-D15 + Crucial Ballistix.
Depending on how you look at it:
A)Crucial Ballistix is too tall; 39mm. NH-D15's front fan will need to be removed. NH-D15 height without moving the front fan is 165mm - there is only clearance for 31mm tall ram sticks.
The specs say 32mm, but it is not ideal to have the fan touching the ram, so there should be a 1mm gap between them.
B)O11 Dynamic doesn't have enough clearance(167mm) to raise the NH-D15's front fan.
C)NH-D15 lacks memory clearance. NH-D15 height without moving the front fan is 165mm - there is only clearance for 31mm tall ram sticks.
Alternative 1: NH-U14S, Deepcool AS500, Thermalright True Spirit Direct, or Macho Rev C.
Apparently, the single tower coolers are more efficient on the Ryzen cpus over the dual towers; power efficiency is so good that these cpus can't 'soak the D15.
Alternative 2: A different chassis that has more room to house your considered components? Lian Li's own Lancool II Mesh?
That's probably asking for too much...
Alternative 3: Low profile ram, such as Corsair Vengeance LPX, Crucial's Ballistix Sport LT, or G. Skill's Aegis.
2)Samsung 980 Pro.
Keep an eye on the temperatures. The heatsink included with the Dark Hero board may not be enough for it, and may require you to look at aftermarket M.2 cooling solutions.
The slot above the gpu is usually the worst location for them.
Alternative: None really, except stepping down to a Gen 3 NVMe or SATA SSD, both of which are much easier to manage thermally.
3)The low profile 120mm fans.
These are 15mm thick instead of the standard 25mm. The caveat is that they're weaker and louder all around compared to the standard size. Their purpose is for scenarios where clearance is tight, which doesn't really exist here.
Also, 140 > 120mm. Your ears will appreciate them more.
Alternative:
Top: 2 NF-A14(Chromax black, if you prefer), or Arctic P14
Bottom: 2 NF-A14, or P14
Unfortunately, the side and rear only allow 120mm - 3 and 1 respectively - a small compromise, I suppose.
That's my 2 cents. Others may suggest or ask about other things.
Reactions: YoIAmDashing
YoIAmDashing
Respectable
Jun 9, 2021
133
12
2,245
Thanks for the advice I really like the fan solution you found. I will make sure to use that. For the 980 pro 2TB I would really prefer to keep that in my build as I need to send large files quickly and I want to play very demanding games. I think I’m going to keep the D15 and change my ram from the Crucial Ballistix 3600mhz c16 2x16GB to the Corsair LPX 3600mhz c16 4x8GB. (I’m so sorry I accidentally wrote mid tower it is actually a Lian li o11 XL)
Phaaze88
Ambassador
Unless you are moving files across multiple NVMes, the speed advantage they have over even SATA3 flies out the window.
That's a hefty premium to pay for the Gen 4 NVMe, IF it turns out that a Gen 3 NVMe - or even a SATA3, for that matter - would've served your purposes greatly, and you could've saved money, or possibly spent it in another area of the build.
Unless you have other NVMes on hand that you're carrying over from another build... it doesn't look like you'll benefit all that much from this particular drive.
Zerk2012
Ambassador
Sticking to one post helps more and yes your still wasting a bunch of money of the motherboard.
https://forums.tomshardware.com/threads/help-me-with-my-pc-build.3707443/#post-22349709
PCPartPicker Part List
Type|Item|Price
CPU | AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor |-
CPU Cooler | be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler | $89.90 @ Amazon
Motherboard | MSI MAG X570 TOMAHAWK WIFI ATX AM4 Motherboard | $257.99 @ Adorama
Memory | Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory | $212.99 @ Corsair
Storage | Samsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive | $310.77 @ B&H
Case | Lian Li Lancool II Mesh ATX Mid Tower Case | $119.99 @ Newegg
Power Supply | Corsair RMx (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply | $189.99 @ Best Buy
| Prices include shipping, taxes, rebates, and discounts |
| Total | $1181.63
| Generated by PCPartPicker 2021-06-16 19:25 EDT-0400 |
Here is the list:
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor ($550.00)
CPU Cooler: Noctua NH-D15 CHROMAX.BLACK 82.52 CFM CPU Cooler ($109.95 @ Amazon)
Motherboard: Asus TUF GAMING X570-PRO (WI-FI) ATX AM4 Motherboard ($219.99 @ Amazon)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory ($172.00 @ Amazon)
Storage: Western Digital Black SN850 (w/Heatsink) 2 TB M.2-2280 NVME Solid State Drive ($469.99 @ Western Digital)
Video Card: NVIDIA GeForce RTX 3090 24 GB Founders Edition Video Card ($1500.00)
Case: Fractal Design Meshify 2 ATX Mid Tower Case ($141.98 @ Newegg)
Power Supply: Corsair RMx (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply ($189.99 @ Best Buy)
Case Fan: Fractal Design Dynamic X2 GP-14 68.4 CFM 140 mm Fan ($18.98 @ B&H)
Total: $3391.86
Generated by PCPartPicker 2021-06-17 02:48 EDT-0400
Save your self good $550.
That ASUS TUF GAMING PRO board will most probably come with latest BIOS out of the box and support the 5000 series CPU with no issues. But even if it doesn't the board comes with BIOS Flashback option. That got you covered. No need to spend high on that Motherboard.
Saved on PSU as well and it will be under less load and be less stressed over time. Which is good.
That Fractal Design Meshify 2 is really good case and is really quiet with good airflow. This gives you overall a very quiet build. That case comes with 3 x 140mm Fans already fitted in it and I included extra 2 Fans which you can install at the Top for extra airflow.
You can spend that saved money towards Monitor to get something like 48" C1 if there is enough space to accommodate it. Or save it and spend that on other peripherals.
YoIAmDashing
Respectable
Jun 9, 2021
133
12
2,245
Here is the list:
Total: $3391.86
I really like the case, motherboard and SSD you have for my build! I was worried about the SSD temperatures the heat sink with do so much cooling wise! I really like noctua fans so I think I’m just going to give the fans that come the case to my friend! Thanks once again.
Danra
Do NOT get a founders edition 3090, the hotspot temperature is very high and will get worse over time. A Noctua NH-D15S leaves enough room for most tall RAM.
YoIAmDashing
Respectable
Jun 9, 2021
133
12
2,245
Btw I don’t really understand fan technology. I understand what makes a fan good but I am clueless of where I should put them which way or anything like that. Where would you recommend me put my fans for intake and outtake?
