Hello, I just put together a new build last night and while putting it together I was a little worried maybe I used too much thermal paste(It wasn't overly to much, but still I am always nervous with it.) and wasn't quite sure which direction to point my aftermarket cooler. Ran it for a few hours last night then woke up today and used Prime 95 for about 15 minutes to test it. I am not sure if I should be looking at the Temperature under CPU or if i should be looking under AMD FX 6300 or a combination of the both. I am using an after market cooler and not oc'd.(If I can get temps right I would like to OC a little). Here is a post of my before and after Prime 95 temps. Any advice would be gladly accepted.
The AMD temperature fluctuates between 11 and 25c at idle and the CPU between 30-35c
After about 15 minutes of Prime 95 the AMD temp was around 38c and the CPU around 50c
