Question New Battery acting weird. Please help.
Oct 9, 2020
Hi, I have a Dell Vostro 14 3468 and recently my battery died. So I bought a new replacement battery on 6th of October, 2020. I followed all the instructions mention and did my first charge to 100%. When I opened the battery report, I came to know that the full charge capacity is around 32500 mWh while designed capacity is 41440 mWh which equals 21 percent wear. I re-calibrated the battery and the wear went down to 9 percent with full charge capacity around 37500 mWh. While using the laptop, when my battery reached 25%, it suddenly went down to 6% although I had used the laptop on battery for almost 4 hours during this time. I tried re-calibrating again and the wear went up to 27%. One more try and it is at 28%. Although it seems that the laptop is providing 4 hours of normal usage on battery but sometimes it acts weird. For example, I charged my battery to full 100% and started using it. When it reached 95%, I plugged it in and it immediately showed Full charged(100%). When disconnected the charger, it went back to 95%. Please guide me whether it is a calibration issue or an issue with the battery.
Here is the present battery report.
Battery report
COMPUTER NAME DESKTOP-PT8THP0
SYSTEM PRODUCT NAME Dell Inc. Vostro 14-3468
BIOS 3.4.0 05/10/2019
OS BUILD 18362.1.amd64fre.19h1_release.190318-1202
PLATFORM ROLE Mobile
CONNECTED STANDBY Not supported
REPORT TIME 2020-10-09 00:54:21
Installed batteries
Information about each currently installed battery
BATTERY 1
NAMEDELL VN3N047
MANUFACTURERSMP
SERIAL NUMBER9001
CHEMISTRYLION
DESIGN CAPACITY41,440 mWh
FULL CHARGE CAPACITY29,467 mWh
CYCLE COUNT -
Recent usage
Power states over the last 3 days
START TIME STATE SOURCE CAPACITY REMAINING
2020-10-06 15:52:04 Active Battery 66 % 21,371 mWh
16:30:55 Suspended 46 % 14,844 mWh
17:11:46 Active Battery 45 % 14,578 mWh
17:24:30 Suspended 5 % 1,732 mWh
17:26:49 Active Battery 4 % 1,288 mWh
17:30:14 Active AC 2 % 681 mWh
17:31:44 Suspended 3 % 1,125 mWh
19:33:54 Active AC 100 % 32,560 mWh
19:33:56 Suspended 100 % 32,560 mWh
19:34:31 Active Battery 99 % 32,382 mWh
20:32:26 Active AC 78 % 25,486 mWh
20:32:30 Battery changed AC --
20:32:30 Active AC --
20:33:29 Battery changed AC --
20:33:29 Active AC --
20:33:31 Suspended --
20:41:04 Battery changed AC 84 % 32,205 mWh
20:41:04 Active AC 84 % 32,205 mWh
20:47:04 Active Battery 88 % 33,996 mWh
21:06:51 Suspended 81 % 31,213 mWh
21:08:50 Battery changed Battery 78 % 25,397 mWh
21:08:50 Active Battery 78 % 25,397 mWh
21:08:50 Suspended 78 % 25,397 mWh
21:09:25 Active Battery 78 % 25,323 mWh
21:13:22 Suspended 76 % 24,657 mWh
21:18:17 Active Battery 72 % 23,547 mWh
23:43:44 Suspended 17 % 5,683 mWh
2020-10-07 01:53:19 Active AC 100 % 37,651 mWh
01:57:59 Active Battery 100 % 37,651 mWh
02:00:55 Suspended 99 % 37,178 mWh
08:27:04 Active Battery 98 % 36,956 mWh
12:25:14 Active AC 6 % 2,176 mWh
12:39:52 Active Battery 18 % 6,808 mWh
12:40:06 Active AC 18 % 6,793 mWh
12:43:08 Active Battery 21 % 7,726 mWh
12:43:15 Active AC 21 % 7,726 mWh
13:15:48 Active Battery 48 % 17,982 mWh
14:30:20 Suspended 26 % 9,975 mWh
17:26:26 Active AC 100 % 33,862 mWh
17:31:24 Active Battery 100 % 33,862 mWh
19:18:51 Suspended 5 % 1,806 mWh
19:20:01 Active Battery 5 % 1,598 mWh
19:20:01 Suspended 5 % 1,598 mWh
19:20:36 Active Battery 5 % 1,495 mWh
19:26:20 Suspended 2 % 725 mWh
21:12:48 Active AC 83 % 24,923 mWh
21:18:30 Active Battery 88 % 26,477 mWh
21:18:38 Active AC 88 % 26,462 mWh
21:48:20 Suspended 100 % 30,074 mWh
21:51:06 Active AC 100 % 30,074 mWh
21:55:16 Active Battery 100 % 30,074 mWh
2020-10-08 01:59:32 Suspended 5 % 1,613 mWh
10:25:31 Active Battery 100 % 29,467 mWh
10:25:31 Suspended 100 % 29,467 mWh
10:26:06 Active Battery 100 % 29,467 mWh
10:26:06 Active AC 100 % 29,467 mWh
10:27:01 Active Battery 100 % 29,467 mWh
13:09:45 Active AC 39 % 11,470 mWh
14:16:11 Suspended 98 % 28,964 mWh
2020-10-09 00:04:39 Active Battery 97 % 28,697 mWh
00:54:21 Report generated Battery 73 % 21,638 mWh
Battery usage
Battery drains over the last 3 days
START TIME STATE DURATION ENERGY DRAINED
2020-10-06 15:52:04 Active 0:38:5120 % 6,527 mWh
17:11:46 Active 0:12:4339 % 12,846 mWh
17:26:49 Active 0:03:242 % 607 mWh
19:34:31 Active 0:57:5421 % 6,896 mWh
20:47:04 Active 0:19:477 % 2,783 mWh
21:08:50 Active 0:00:00--
21:09:25 Active 0:03:572 % 666 mWh
21:18:17 Active 2:25:2755 % 17,864 mWh
01:57:59 Active 0:02:551 % 473 mWh
08:27:04 Active 3:58:1092 % 34,780 mWh
12:39:52 Active 0:00:13-15 mWh
12:43:08 Active 0:00:07--
13:15:48 Active 1:14:3121 % 8,007 mWh
17:31:24 Active 1:47:2695 % 32,056 mWh
19:20:01 Active 0:00:00--
19:20:36 Active 0:05:443 % 770 mWh
21:18:30 Active 0:00:08-15 mWh
21:55:16 Active 4:04:1695 % 28,461 mWh
10:25:31 Active 0:00:00--
10:26:06 Active 0:00:00--
10:27:01 Active 2:42:4361 % 17,997 mWh
2020-10-09 00:04:39 Active 0:49:4124 % 7,059 mWh
Usage history
History of system usage on AC and battery
BATTERY DURATION AC DURATION
PERIOD ACTIVE CONNECTED STANDBY ACTIVE CONNECTED STANDBY
2020-08-09 - 2020-08-160:00:13-11:28:19-
2020-08-16 - 2020-08-230:00:22-5:23:30-
2020-08-23 - 2020-08-302:28:27-15:48:40-
2020-08-30 - 2020-09-060:21:39-26:52:35-
2020-09-06 - 2020-09-130:10:31-11:55:39-
2020-09-13 - 2020-09-200:08:44-5:51:25-
2020-09-20 - 2020-09-270:04:09-28:29:20-
2020-09-27--5:18:57-
2020-09-280:00:01-7:53:07-
2020-09-290:02:22-1:01:50-
2020-09-300:06:28-10:34:43-
2020-10-010:02:05-6:43:50-
2020-10-020:08:46-4:55:41-
2020-10-03--3:16:04-
2020-10-04--2:59:17-
2020-10-050:00:04---
2020-10-064:41:55-0:08:34-
2020-10-079:13:04-1:36:32-
2020-10-084:42:11-1:07:20-
Battery capacity history
Charge capacity history of the system's batteries
PERIOD FULL CHARGE CAPACITY DESIGN CAPACITY
2020-08-09 - 2020-08-162,812 mWh 41,440 mWh
2020-08-16 - 2020-08-2310,953 mWh 41,440 mWh
2020-08-23 - 2020-08-3032,087 mWh 41,440 mWh
2020-08-30 - 2020-09-064,726 mWh 41,440 mWh
2020-09-06 - 2020-09-134,677 mWh 41,440 mWh
2020-09-13 - 2020-09-203,405 mWh 41,440 mWh
2020-09-20 - 2020-09-272,057 mWh 41,440 mWh
2020-09-282,057 mWh 41,440 mWh
2020-09-292,057 mWh 41,440 mWh
2020-09-302,057 mWh 41,440 mWh
2020-10-012,057 mWh 41,440 mWh
2020-10-022,057 mWh 41,440 mWh
2020-10-032,057 mWh 41,440 mWh
2020-10-042,054 mWh 41,383 mWh
2020-10-052,057 mWh 41,440 mWh
2020-10-0632,878 mWh 41,440 mWh
2020-10-0735,478 mWh 41,440 mWh
2020-10-0829,730 mWh 41,440 mWh
Battery life estimates
Battery life estimates based on observed drains
AT FULL CHARGE AT DESIGN CAPACITY
PERIOD ACTIVECONNECTED STANDBYACTIVECONNECTED STANDBY
2020-08-09 - 2020-08-160:13:32-3:19:31-
2020-08-16 - 2020-08-230:45:38-2:52:40-
2020-08-23 - 2020-08-303:26:56-4:27:16-
2020-08-30 - 2020-09-060:30:26-4:26:56-
2020-09-06 - 2020-09-130:09:46-1:26:34-
2020-09-13 - 2020-09-200:23:21-4:44:17-
2020-09-20 - 2020-09-270:16:02-5:23:15-
2020-09-27----
2020-09-28----
2020-09-290:08:53-2:58:58-
2020-09-300:14:29-4:51:54-
2020-10-010:26:27-8:52:55-
2020-10-020:16:54-5:40:47-
2020-10-03----
2020-10-04----
2020-10-05----
2020-10-063:12:20-4:02:26-
2020-10-073:27:47-4:02:42-
2020-10-084:58:26-6:55:58-
Current estimate of battery life based on all observed drains since OS install
Since OS install 3:09:40-4:26:44-
