I need to know, is this setup sufficient for running 3d programs like 3ds max, vray and lumion? Is gtx 1050ti (4gb variant) sufficient? I don't want to get a pro card. I expect this setup to last 5-6 years. So, my overall requirements call for a consumer graphic card. I am making do with a dual core 1.7ghz processor and on board graphics on a 8-9 year old laptop so this is gonna be leaps and bounds ahead regardless.
Note: If you have any suggestions or want to suggest a different system build, please use the 'Build Your Own PCs' provided on mdcomputers.in
PS: To check prices, please use the above site.
Thanks, I appreciate your time
Approximate Purchase Date: In 2 months (ie. in Feb/March)
Budget Range: Rs 60,000 (Indian Rupees) including monitor
System Usage from Most to Least Important: 3d rendering, gaming (at 60 fps in 720p at least), editing, watching hd movies
Are you buying a monitor: Yes
Parts to Upgrade: N/A (Buying all parts new)
Do you need to buy OS: No
Preferred Website(s) for Parts: mdcomputers.in (because the actual brick-n-mortar store is in my city)
Parts Preferences:
CPU: INTEL i5 7500 Kaby Lake 3.4 Ghz base clock 3.8 Ghz boost clock Rs. 16,700
Motherboard: MSI B250M MORTAR (INTEL SOCKET 1151MAX 64GB RAM of upto 2400Mhz DDR4 RAMs) Rs. 8,715
RAM: CORSAIR RAM VENGEANCE LPX 16GB (2x8GB) DDR4 2400MHZ Rs. 7,980
Hard Disk: WESTERN DIGITAL HARD DISK 1TB SATA BLUE Rs. 3,520
Graphic Card: ZOTAC GTX 1050 TI 4GB GDDR5 OC Rs. 13,250
Power Supply: CORSAIR SMPS VS550 - 550 WATT PSU Rs.3,410
Case: DEEPCOOL MID TOWER CABINET (ATX) - TESSERACT SW with 2 fans Rs.3,250
Monitor: SAMSUNG MONITOR 18.5" LED With IPS Panel Rs.5,210
TOTAL: Rs. 62,035.
Overclocking: No
SLI or Crossfire: No
Your Monitor Resolution: 1366 x 768 of the one I'm buying. I don't need an advanced one because I already have a 28 inch HD tv for movies etc.
Additional Comments: Softwares to be run on this system: AutoCAD 2017, Sketchup 2017 with VRay rendering ver 2.0, Lumion, Adobe Photoshop CS6
And Most Importantly, Why Are You Upgrading: I have a very old laptop which is on its deathbed.
Include a list of any parts you have already selected with descriptively labeled links for parts. Please do not post only links.
Parts Preferences:
TOTAL: Rs. 62,035.
Overclocking: No
