New build booting problems
DaPotatoes
118
I just built my new build and after trying to boot it started up for a second then it shutdown it keeps doing this. I tried the psu shorting method with a paper clip and it worked fine. So check everything still happening... Tried to boot up with different psu and it worked. So any suggestions?
Interesting, maybe you bought a version that was the wrong voltage. In any case if you want to return it you should follow this http://www.evga.com/howtorma/ don't RMA to the seller, the manufacturer will be more helpful.
Evga power supply's don't have one I'm just going to send it back
