I'm pretty sure this goes under memory, but it could just as easily be a board or apu problem. I just put together an A6-6400k apu with an Asrock FM2A75m-Pro4+. I have 4gb of 1333 memory (2x 2gb). CPU-Z is reporting a bus speed and rated fsb as 98.82MHz. This can't be correct, right? The CPU-Z memory tab reports DRAM Frequency as 665.5MHz, and the SPD tab reports max bandwidth as PC3-10700H (667MHz). The graphics tab has everything grayed out except gpu name and memory size. I ran 3DMark on it also, if those results will shed any light on anything.
