new build but confused for the parts needed
Killeryan
11
I recently have started working on a new build for my friend and have bought
Gigabyte B75M-D3H MOBO
Cooler master Thunder 450W psu
Now m confused about the gpu nd cpu
For cpu m considering i5 3570
For gpu m considering gtx 650ti /HD 7770 OR ANY YOUR ADVICE
The computer will be basically used for coding nd gaming
While the budget is a bit of a constrained about 500$
The i5-3470 is a good processor for that motherboard.
That will leave you with a good ~$300-320.
For a gaming build, I would seriously just replace that psu. 450w is pretty low for a high end gpu and Cooler Master psus generally aren't that great. Return it if you can. Otherwise, you have two options:
1. Just go with a GTX 760 and hope it doesn't blow up on you.
2. Just buy a new, better PSU and a R9-280X.
Sorry bro cannot replace that psu with any other had ordered it onlyn nd they dont have any replacement or refund policy regarding electronics.So i wud hav to use that only.Wud u jst get me a gpu for that cooler master psu.
But if m not wrong the 760 requires min. 500 w power supply aint it???
It consumes 170w whereas the processor will only consume around ~85w. That's only 255w from the two main wattage consuming components of a rig. Add about an extra 50-100w for the other components and it'll be under 450w. Let's just hope the psu can still handle it.
The mobo can use ati crossfire so i m thinking of buying an ati card and then ib future wen needed to upgrade the psu and crossfire with another gpu so wud u recommend an amd card for that bro
