I'm not new to computers but I am mostly illiterate to the Hardware side of things. I game / stream / create content etc. so I wanted my build to be pretty beefy. The PROBLEM I'm running in to is, this things gets HOT. MY CPU is water cooled and runs at around 50c under load, top GPC around 60 and bottom around 77c again under load. The problem is (Fintek F71889AD) which I still don't know what that is BUT that things gets upwards to 92c etc.
I'll post my specs below.
Mobo Evga x299 Dark
Processor Intel Core i9-9820
32 GB Ram
Windows 64 Bit Pro
Nvidia Geforce RTX 2080 TI x 2 NVLink
Elgado 4k60pro
Samsung SSD 860 Evo 4 TB
HGST 4 TD
Everything runs cool except the (Fintek F71889AD) when under load (gaming mostly or streaming) it gets up to 92-95c consistently. My outer case (glass is also very warm to the touch)
I'll post the log while my CPU is idle
+- 151-SX-E299 (/mainboard)
| +- Fintek F71889AD (/lpc/f71889ad)
| | +- VCC3V : 3.264 3.264 3.264 (/lpc/f71889ad/voltage/0)
| | +- CPU VCore : 1.152 1.152 1.152 (/lpc/f71889ad/voltage/1)
| | +- Voltage #3 : 0.816 0.816 0.816 (/lpc/f71889ad/voltage/2)
| | +- Voltage #4 : 0.928 0.928 0.936 (/lpc/f71889ad/voltage/3)
| | +- Voltage #5 : 0.992 0.992 0.992 (/lpc/f71889ad/voltage/4)
| | +- Voltage #6 : 0.816 0.816 0.816 (/lpc/f71889ad/voltage/5)
| | +- Voltage #7 : 1.296 1.288 1.296 (/lpc/f71889ad/voltage/6)
| | +- VSB3V : 3.392 3.392 3.392 (/lpc/f71889ad/voltage/7)
| | +- VBat : 3.088 3.088 3.104 (/lpc/f71889ad/voltage/8)
| | +- Temperature #1 : 43 43 43 (/lpc/f71889ad/temperature/0)
| | +- Temperature #2 : 44 44 44 (/lpc/f71889ad/temperature/1)
| | +- Temperature #3 : 36 36 36 (/lpc/f71889ad/temperature/2)
| | +- Fan #2 : 1827.04 1796.41 1831.5 (/lpc/f71889ad/fan/1)
| | +- Fan #3 : 3067.49 3054.99 3131.52 (/lpc/f71889ad/fan/2)
+- Intel Core i9-9820X (/intelcpu/0)
| +- CPU Total : 0.937498 0.937498 5.80357 (/intelcpu/0/load/0)
| +- CPU Core #1 : 2.34375 2.34375 50 (/intelcpu/0/load/1)
| +- CPU Core #2 : 0 0 4.01785 (/intelcpu/0/load/2)
| +- CPU Core #3 : 0.78125 0 7.58929 (/intelcpu/0/load/3)
| +- CPU Core #4 : 0.78125 0 2.67857 (/intelcpu/0/load/4)
| +- CPU Core #5 : 0.78125 0 5.35715 (/intelcpu/0/load/5)
| +- CPU Core #6 : 0 0 7.14285 (/intelcpu/0/load/6)
| +- CPU Core #7 : 0 0 8.03571 (/intelcpu/0/load/7)
| +- CPU Core #8 : 3.125 0 5.80357 (/intelcpu/0/load/8)
| +- CPU Core #9 : 0.78125 0 4.01785 (/intelcpu/0/load/9)
| +- CPU Core #10 : 0.78125 0 1.78571 (/intelcpu/0/load/10)
+- Generic Memory (/ram)
| +- Memory : 28.8925 28.8925 28.9575 (/ram/load/0)
| +- Used Memory : 9.1569 9.1569 9.17748 (/ram/data/0)
| +- Available Memory : 22.5361 22.5155 22.5361 (/ram/data/1)
+- NVIDIA GeForce RTX 2080 Ti (/nvidiagpu/0)
| +- GPU Core : 300 300 300 (/nvidiagpu/0/clock/0)
| +- GPU Memory : 405 405 405 (/nvidiagpu/0/clock/1)
| +- GPU Shader : 0 0 0 (/nvidiagpu/0/clock/2)
| +- GPU Core : 40 40 41 (/nvidiagpu/0/temperature/0)
| +- GPU Core : 1 1 11 (/nvidiagpu/0/load/0)
| +- GPU Memory Controller : 6 6 7 (/nvidiagpu/0/load/1)
| +- GPU Video Engine : 0 0 0 (/nvidiagpu/0/load/2)
| +- GPU Memory : 7.73638 7.73527 8.03434 (/nvidiagpu/0/load/3)
| +- GPU Memory Free : 10392.6 10359 10392.7 (/nvidiagpu/0/smalldata/1)
| +- GPU Memory Used : 871.426 871.301 904.988 (/nvidiagpu/0/smalldata/2)
| +- GPU Memory Total : 11264 11264 11264 (/nvidiagpu/0/smalldata/3)
+- NVIDIA GeForce RTX 2080 Ti (/nvidiagpu/1)
| +- GPU Core : 300 300 300 (/nvidiagpu/1/clock/0)
| +- GPU Memory : 405 405 405 (/nvidiagpu/1/clock/1)
| +- GPU Shader : 0 0 0 (/nvidiagpu/1/clock/2)
| +- GPU Core : 38 38 38 (/nvidiagpu/1/temperature/0)
| +- GPU Core : 0 0 0 (/nvidiagpu/1/load/0)
| +- GPU Memory Controller : 0 0 0 (/nvidiagpu/1/load/1)
| +- GPU Video Engine : 0 0 0 (/nvidiagpu/1/load/2)
| +- GPU Memory : 7.73638 7.73527 8.03434 (/nvidiagpu/1/load/3)
| +- GPU Memory Free : 10392.6 10359 10392.7 (/nvidiagpu/1/smalldata/1)
| +- GPU Memory Used : 871.426 871.301 904.988 (/nvidiagpu/1/smalldata/2)
| +- GPU Memory Total : 11264 11264 11264 (/nvidiagpu/1/smalldata/3)
+- HGST HDN724040ALE640 (/hdd/0)
| +- Temperature : 38 38 38 (/hdd/0/temperature/0)
| +- Used Space : 0.0218887 0.0218887 0.0218887 (/hdd/0/load/0)
+- Samsung SSD 860 EVO 4TB (/hdd/1)
| +- Temperature : 32 32 32 (/hdd/1/temperature/0)
| +- Used Space : 13.8208 13.8208 13.8208 (/hdd/1/load/0)
| +- Total LBA Written : -986.059 -986.059 -986.059 (/hdd/1/data/0)
Mobo Evga x299 Dark
32 GB Ram
Windows 64 Bit Pro
Elgado 4k60pro
HGST 4 TD
I don't think this is of concern however.
