Just finished building my new system
ASRock B450M Steel Legend
R5 2600x with Deep Cool Gammaxx GTE 2.0
G.Skill 16GB 3200
Using my old HD6970 GPU for now
Antec NeoEco 550w PSU
All hardware is new with the exception of my GPU. I used the supplied thermal paste that came with Deep Cool cooler.
In the bios the CPU temps go up to 48c
In Windows on idle my cpu temps are bouncing around from high 30's to mid 40's according to CAM
Are these idle temps normal for a brand new CPU with an aftermarket cooler? My ambient temp is around 28C. I would think the CPU temp. should be at least 10 degrees cooler with the aftermarket cooler. And yes I removed the sticker on the bottom of the heatsink.
Thanks.
G.Skill 16GB 3200
Thanks.
