Hi All,
I'm building a PC with a custom waterloop at the moment, and need some suggestions regarding fans & pump using PWM
I'll start with the parts relating to my issue.
MSI z170 gaming M7 motherboard,
NZXT Noctis 450 with PWM fan hub.
Case comes with 3 fans in front, (removed 2, replaced with rad and 2 fans)
2 radiators, one in front one on top each with 2, 4 pin fans.
EK-XRES 140 DDC 3.2 PWM Elite Pump/Reservoir Combo
My issue is that the PWM hub only has 3 pin connections.
My motherboard has 5, 4 pin fan headers, and the speed can be changed in the bios for all 5.
If i plug the 4, 4pin fans into the 3 pin headers on the PWM hub (which connects to the cpu_fan on mobo) then they will run in voltage control mode (im assuimng 100%?) They're 3000rpm fans (EK Furious Vardar Fan F5 120mm) so if theyre running at 100% the whole time that will be really noisy.
And then theres the pump, the connector is a 4pin connector however theres only 2 wires coming out of it, and its supposedly PWM? Thats another thing i dont want running 100%, if that blows it will be a disaster.
Everything was going so well with the build this whole fan situation is confusing the hell out of me =(. To make matters worse the top fans dont even reach the PWM hub.
I dont know if i should just get a fan controller like the NZXT Grid+ V2 and a cable extensions?
Sorry for the long post. Any advice would be really appreciated
