Hello there, I am looking for some help if possible.
I recently tried building my first computer. When I tried to turn it on for the first time, there was nothing. The power supply fan did not start, the case fans did not start; nothing happened at all. When I first connected the power supply to the outlet and flipped the switch, I did notice that the LED on the motherboard came on.
I disconnected everything from the motherboard and removed it from the case. Right now, I have a power supply, the mother board, the processor with fan/heat sink, and a stick of RAM inserted into the mother board. I am getting the same results as described above.
On reading the "PERFORM THESE STEPS..." checklist, I did 1-3, skipped 4 and 5 since I have no video card, and did 6-11.
Regarding 12, I did spill some thermal paste when I was connecting the CPU fan. It is entirely possible that all of my problems are due to this disaster, although I cannot tell. Some went on the motherboard, and some went in the general area where the processor sits. I tried very hard to clean all of it off using rubbing alcohol, cotton swaps, and toothpicks. I do not see anymore on there right now.
I did 13-16, skipped 17 (I do not think I have a system speaker, although I may be wrong), did 18-21, skipped 22 (again, does not apply), and did 23.
Since nothing at all happens when I apply power (excepting the illuminating of the LED on the mother board), I also tried the "paper clip test" on the power supply. I hooked it up to a case fan and the paper clip and turned it on. The case fan and the power supply fan started right up. I also had two sticks of RAM and tried each of them as the only one with no success. So right now I guess I am most suspicious of the motherboard and the processor. I do not know how to continue from here. I also am having a difficult time imagining how I can determine if, supposing one of those two parts is not working, it is due to my thermal paste spill or not.
Here are the parts:
Case: Fractal Design Arc Midi R2 FD-CA-ARC-R2-BL-W Black
Motherboard: ASUS Z97-A
Processor: Intel Core i5-4590
Power supply: ANTEC Gold Standard Power Supply ATX 650 Power Supply TP-650C
Memory: Kingston Value RAM 4GB 1600MHz PC3-12800 DDR3 Non-ECC CL11 DIMM SR x8 Desktop Memory (KVR16N11S8/4)
When I try to power the system up in its current configuration, I do so by manually pressing the PWR_SW button at the bottom of the motherboard. Doing so makes me extremely nervous -- is this the right way to test? Does anyone else have any ideas? Thank you in advance!
Here are the parts:
