Okay, so I'm not sure what information is or isn't relevant and a lot happened, so I'll list in steps what happened.
!) Got everything hooked up, turned power on, pushed power button, all fans are spinning, hard drive is spinning, DVD drive is working, except GPU fan is not spinning and there's no beep.
2) GPU came with ysplit molex to 6pin so I used that. This time even less happened. All fans spun, stopped, spun again, and this just continued.
3) Next day, used the 6pin from PSU to connect to GPU in PCIe x16 slot. Pushed in all connections from PSU into sockets even tighter. All fans work now, including GPU fan. Still no POST beep and the monitor doesn't have a signal. PCIe x8 slot has the same result. Monitor only came with VGA cable so using a VGA to dvi adapter to connect to GPU.
Thoughts? Motherboard issue, GPU issue, both?
Case: CM Haf 912 (2 stock fans)
CPU: AMD Fx-6300
Heatsink/fan: CM 212+
GPU: Visiontek Radeon HD 7850 (PCIe x16)
Memory: 8gb gskills ripjaws 1600
MB: Gigabyte 970a D3
PSU: Corsair CX500
CPU: AMD Fx-6300
PSU: Corsair CX500
