I just put together a new build - when switched on, the fans all run, but I can't get any signal to the monitor. I initially tried with the GPU, got no signal, so I removed the GPU and plugged the monitor into the MB panel, and still no display. I tried both display port and HDMI. I tried re-seating the memory, and tried each 8gb module independently. I disconnected the hard drives as well. I've checked all connections. Always the same result. I'm not getting as far as the MB splash screen and can't access BIOS.
There are no LEDs on the MB that indicate it's alive. However, the cpu fan and 2 case fans are running, and the case on/off switch works. The MB didn't come with a speaker, and has a narrow 2-pin speaker connector that doesn't fit any of the regular 4-pin MB speakers, so I'm not getting any beeps to tell me if it's succeeding/failing to boot.
MB: Gigabyte Z690i Aorus Ultra Lite DDR5
CPU: i5 12600
RAM: Patriot Viper Venom DDR5 5600 2x8GB
PSU: SeaSonic SS-460FL
One remote possibility is the 8-pin 12v CPU power plug is folded over tightly and squeezed between the case and MB. Would all the fans be running if the 12v cpu power wasn't connected properly?
Any other suggestions? I'm at a loss at this point.
CPU: i5 12600
