Hi everyone, I am needing some advice. I am to finally upgrade my system after 5 years. I want a PC that will be able to play this gen and next gen titles such as Fallout 4 and Assassins Creed (ideally) on Ultra if not high.
I did have a budget of £1500 (it is currently a little over, if you check the link to a PC Part Picker build).
So a few questions in regards to this build:
Will this i5 6600k bottleneck a 980/980ti?
Would a 980 be sufficient enough to game on this monitor and play games on high settings?
Is there anyway I can save on this build? (I am using a CM Storm Scout 2 Advanced Case and an AX 760 PSU)
Also I have Windows 10 on my machine at the moment, will I be able to use this without having to purchase another licence?
Please feel free to edit this build I am open to recommendations
Edit: This is what I have whittled it down to. what do you think? Should I get an i7 6700k or would I see no difference in gaming?
Link to PC build-
http://uk.pcpartpicker.com/p/Ls8D99
Link to PC build-
