Hey guys,
I'm putting a new pc together for heavy rendering in 3dmax and the sorts. if you can just tell me which build would be a better system. I won't do any gaming with this machine, I have a different pc for gaming.
they both cost roughly the same and are already almost stretching the budget.
the common hardware between the 2 builds will be:
Seagate® Barracuda™ 7200.12 Series - 500GB Serial ATA II
GIGABYTE® ODIN GT 550W Modular Power Supply
Build 1
Intel® Boxed Core™ i7 920 Processor - 2.66GHz Quad Core
XFX Intel X58, LGA1366 motherboard
Transcend® JetRam™ High-Performance Tri-Channel 2GB DDR3-1333, 6gigs total
2x XFX GTX260 running SLI
Build 2
INTEL Core2 Quad Q9400-2.66Ghz CPU -6MB Cache
Gigabyte EP43-UD3L LGA775 Motherboard
4x Transcend Jetram 2GB DDR2-800, 8gigs total
Nvidia FX3800 Quadro
if someone could just help me, i dont know how much the processor works when working with intense graphics. basically the difference between the 2 builds is that the one has the better and more expensive Graphics so i had to get the slower CPU. and the other is a stronger CPU but more gaming orientated Graphics.
One option I was thinking of is swopping the 2 GTX260's for a FX1800 Quadro. which would be better? the quodro would have half the memory.
please help. any other similar builds which you might suggest would be helpful. thanks
Build 1
Build 2
