Howdy everyone. Happy Turkey day! Its been many years but recently i decided to jump back into the PC building game and gift myself something new. I'm on vacation so i thought what better way to spend my time than to build me a new rig/beers/gaming and have fun..............but no....Build decided to be a mother@!%#$^%$......., so I decided to come here for assistance from the pros. It's my 1st AMD build. Here is the build list:
Build:
Motherboard: Asus ROG X570 VIII Hero
CPU: AMD Ryzen 7 3800
GPU: EVGA RTX 2080 Ti
Secondary GPU: an older GTX 1080(from a prev build)
Monitor: Acer Predator x34 and 2 1080p monitors(all 3 from prev build)
Boot drive: Samsung 970 evo @ 1tb NVME
Additional storage: Samsung 860 QVO SSD 2tb
RAM: Corsair Vengeance rgb pro(4x16gb) ddr4 @ 3200
PSU: Corsair RMX RM850w Gold
This is what i get after the build
Troubleshooting:
Please note: The only items i am using currently from my prev build is the display port cable, my Acer Predator x34 monitor, 2 1080p monitors and a GTX 1080 founders.
With this new build, i have a 3 monitor setup. The left and right monitors are 1080p screens, and in the center i have my Acer Predator that I've had for a few years. I am having an issue where at random times(about every 10-30 minutes while in use), the Predator monitor will either go black, or do this(File attached because i cant explain it). But it did not do this before. Considering that my old build was working as late as yesterday, and i was using the same monitor and Display Port cabling without any issues whatsoever, i figured the predator cant be the problem and instead probably a faulty GPU so I went and returned the RTX2080 to Amazon, and not wanting to wait, ran to Best Buy and got another RTX 2080. Put it back into the system, and the same issue. Almost immediately got the black screen.
Process of elimination, I figured i'd eliminate the RTX cards themselves being the issue since I've tried two new cards, and move onto the DisplayPort(DP) cable itself. Realizing i didn't have a spare, I ran back to BestBuy and got a new DP cable, installed it and nothing. The same issue, black screen or the image attached. I did notice though that whilst having the messup on the predator, that the two side monitors(HDMI) were ok and viewed perfectly fine. Still confused, i figured i have two things left to troubleshoot. The Predator itself, or the motherboard. With my luck, i figured it'd be the predator so further troubleshooting I kept everything the same and didn't remove anything. The only change being to take out the DP cable off of the RTX2080, and connect it to the GTX1080 and lo n behold. it works. Played a few games, and been on for a few hrs and no more issues. Its like nothing bad happened.
I'm confused because, since it works, it rules out the last two things which was the motherboard and the predator monitor. Been running the new build on the old 1080 for a few hrs now and no issues. Last minute i thought about the PSU, took it to pc part picker, and rounded everything up, for a total of around 550W. Also went online and used wattage calculators which both read around 729W. Both of which my 850W covers. so yeah...not sure what the deal is. Im at my witts end and at this point, not sure what to do. I have effectively tested everything i could but to no avail. Any ideas? Anything im missing?Any assistance is greatly appreciated. Thank you kindly in advance.
Build:
Troubleshooting:
