Question New Build Help $2500, Help Nytmare
Nytmare
134
9
18,685
Hello all !
It time to upgrade my existing desktop. The prior build is about 6 years old and showing its age.
So here is what I picked out for the upgrade. The computer would be used for gaming and some work -_-
My gaming is mainly at 1080. I am not sure my Asus 34” curved monitor would support 4k.
Please look at the build and give me your suggestions. Thank you in advance.
-Not sure if the Corsair H100i V2 CPU cooler can be used on the new build, so I did pick out a new cooler.
-I have had good luck with Asus, Corsair, Gskill, but open to your input.
My budget is around $2500 USA.
Preferred site: Newegg.com
Overclocking: never done it, but may do it with this build
CPU:
Intel Core i5-13600K - Core i5 13th Gen Raptor Lake 14-Core (6P+8E) 3.5 GHz LGA 1700 125W Intel UHD Graphics 770 Desktop Processor - BX8071513600K
CPU COOLER:
CORSAIR CW-9060060-WW iCUE H150i RGB ELITE Liquid CPU Cooler
MOBO:
ASUS ROG Strix Z790-F Gaming WiFi 6E LGA 1700(Intel® 13th&12th Gen) ATX gaming motherboard(16 + 1 power stages,DDR5,four M.2 slots, PCIe® 5.0,WiFi 6E,USB 3.2 Gen 2x2 Type-C® with PD 3.0 up to 30W)
GPU:
ASUS TUF Gaming NVIDIA GeForce RTX 3080 V2 OC Edition Graphics Card (PCIe 4.0, 10GB GDDR6X, LHR, HDMI 2.1, DisplayPort 1.4a, Dual Ball Fan Bearings, Military-grade Certification, GPU Tweak II)
MEMORY:
CORSAIR Vengeance RGB 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model CMH32GX5M2D6000C36
-OR-
G.Skill Trident Z5 RGB Series (Intel XMP) 32GB (2 x 16GB) 288-Pin SDRAM DDR5 6000 CL36-36-36-96 1.35V Dual Channel Desktop Memory F5-6000J3636F16GA2-TZ5RK (Matte Black)
SOLID STATE DRIVE:
SK hynix Platinum P41 2TB PCIe NVMe Gen4 M.2 2280 Internal SSD l Up to 7,000MB/S l Compact M.2 SSD Form Factor SK hynix SSD - Internal Solid State Drive with 176-Layer NAND Flash
-OR-
SAMSUNG 970 EVO PLUS M.2 2280 2TB PCIe Gen 3.0 x4, NVMe 1.3 V-NAND 3-bit MLC Internal Solid State Drive (SSD) MZ-V7S2T0B/AM
HARD DRIVE:
? not sure
Equipment that I have and planning on keeping in the new build:
Full Lian Li Tower Case
Corsair HX Series, HX1000, 1000 Watt, Fully Modular Power Supply, 80+ Platinum Certified,
Corsair Hydro Series H100i V2 Extreme Performance Water / Liquid CPU Cooler. 240mm (CW-9060025-WW)
Sound Blaster AE-5 Plus Sound Card
ASUS Republic of Gamers Swift PG348Q 34" 21:9 Curved Ultra-Wide G-Sync IPS Monitor
• In-Plane Switching (IPS) Technology
• HDMI + DisplayPort Inputs
• 3440 x 1440 Resolution
• 1000:1 Static Contrast Ratio
Old Equipment that is available:
SAMSUNG 960 EVO M.2 250GB NVMe PCI-Express 3.0 x4 Internal Solid State Drive (SSD) MZ-V6E250BW
WD 1 TB Hard Drive
Your monitor is the resolution, you can’t display any more than the monitor is capable of? It’s a 1440p UW monitor it can do 1440p UW.
You have a CPU cooler listed on the build and a different one you say you intend to keep and reuse in the build.
You could probably go AMD for the CPU with a 7700X and get a 3080Ti or a 7900XTX/4080 in there too for under 2500.
Also with DDR5 make sure the meteors you buy is listed as compatible with the motherboard QVL list otherwise there’s a decent change it won’t work
Personally I would do something like this;
PCPartPicker Part List
CPU: Intel Core i5-13600K 3.5 GHz 14-Core Processor ($319.98 @ Amazon)
CPU Cooler: ARCTIC Liquid Freezer II 360 56.3 CFM Liquid CPU Cooler ($124.99 @ Amazon)
Motherboard: MSI PRO Z790-P WIFI ATX LGA1700 Motherboard ($239.99 @ B&H)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory ($149.99 @ Newegg)
Storage: Samsung 980 Pro 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($99.99 @ Amazon)
Storage: Crucial P3 4 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($249.99 @ Amazon)
Video Card: ASRock OC Formula Radeon RX 6900 XT 16 GB Video Card ($699.99 @ Newegg)
Case: Lian Li LANCOOL III RGB ATX Mid Tower Case (Purchased For $0.00)
Power Supply: Corsair RM850x (2021) 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($139.97 @ Amazon)
Total: $2024.89
Generated by PCPartPicker 2022-12-14 13:11 EST-0500
If you have to go Nvidia, this is about as good as it gets with that budget right now;
Video Card: Asus TUF GAMING GeForce RTX 4080 16 GB Video Card ($1199.99 @ ASUS)
Total: $2524.89
Generated by PCPartPicker 2022-12-14 13:14 EST-0500
Nytmare
134
9
18,685
Thanks a lot for the suggestions.
1. I do have a CPU cooler on my old build.
-Can I use it on a new build, or is it too old and will not work?
2. I have a pretty good PSU on the old build.
-Where would you put the saved $ on another area of the build?
3. I have had good luck with Asus MOBO's. Thoughts on the MSI MOBO vs my ASUS choice ?
4. Storage: Is it preferable to go SSD on both the boot drive and the secondary drive? I was thinking SSD for boot drive and then standard HD for secondary data HD ?
5. I would prefer to stick to NewEgg and Amazon.
Thanks !
https://www.newegg.com/crucial-4tb-p3/p/N82E16820156298?quicklink=true
The 4 TB Crucial P3 is 250 right now at New Egg. It is going on sale in a couple of hours for one day. I don't know what the sale price will be, but worth a look.
Asus seems to be fading in popularity on this site. Not sure how valid that is.
I'd certainly try to avoid spinning hard drives entirely if possible.
Maybe a smallish SSD (probably NVMe; maybe 500 GB) for the boot drive and applications and a big one (2 or 4 TB) for all data....could be ordinary 2.5 inch SATA if budget requires that.
Reactions: helper800
I think people are becoming jaded with the ROG tax, lack of certain features at lower prices, falling customer support confidence, and they do not seem to have the edge with stability and bugginess involving their software and BIOS for their products. I personally prefer ASUS products over MSI, but the latter makes good motherboards still, I just try and avoid their lower end graphics cards.
Ar558
Proper
Dec 13, 2022
228
93
160
A 3080 is overkill for 1080p gaming in almost all cases. Unless you're one of those "competitive" gamers who claims they can tell the difference between 144hz and higher (Which is scientifically impossible but I wont go into that). Is your 34" Monitor native 1080p as that seems low? If you are considering gaming at 1440p the 3080 makes more sense, other wise a 3070/6750XT would be more sensible.
Show me the research paper telling me there is no visual difference between a 144hz and a 144hz+ monitor to the human eye.
He said he has an ASUS ROG Swift PG348Q 3440 x 1440 monitor, so clearly he will benefit from as much GPU horse power he can buy.
Ar558
Proper
Dec 13, 2022
228
93
160
Every single test I have seen using normal people in blind testing, shows no statistical ability to show a difference. It's irresponsible to encourage people to spend money on expensive equipment that will make little to no difference to their actual usage.
He said he games at 1080, if he intends to continue that he is not going to benefit.
You mean, in your opinion, he will not benefit. Ascribing your opinion as fact is not responsible. Give your opinion and any support you deem necessary to let the OP decide. Like I said he already has a top of the line UW 1440p monitor, he can choose any resolution he deems is necessary, and if he ever want to take advantage of the monitors native resolution is some demanding games he will need the graphics horsepower.
Please, would you kindly, post a link to one or more of these tests you are referencing. Personally I can tell the difference between 120 /144/ 165 fairly easily. I can see that anything beyond 165hz as being smoother than 165 and below, but cannot tell you if its 240hz or 1000hz. The actualized benefit of those extra frames in a game is subjectively beneficial or neutral. Just because some, or potentially most, people cannot perceive or gain a benefit from those extra frames, that does not mean the OP will not. He already has the monitor to support whatever he pleases and is asking for a graphics card recommendation, and for his monitor it would be nothing less than a 3080. There are games a 3080 cannot get 60fps at 1080p with higher settings, let alone 3440x1440p.
Thanks !
You can save money by potentially reusing the AIO and the PSU, but a word of caution; PSUs ability to provide its advertised wattage lowers with age, and AIOs slowly lose their ability to work due to losing water through a process called permeation. Usually AIOs are good for up to 5-6 years. If yours is past that in age I would replace it. PSUs are usually good through the length of their warranty and I believe that one has a 10 year warranty. If its older than that I would consider replacing it.
Nytmare
134
9
18,685
Okay,
After reading the above replies....
I should clarify the resolution comment. The above monitor (ASUS Republic of Gamers Swift PG348Q 34" 21:9 Curved Ultra-Wide G-Sync IPS Monitor ), I would like to keep for the time being. The maximal resolution of the monitor is 3440 x 1440. Thus, if I have the ability on the computer to go higher than 1080 for gaming I will use the available power.
Playing around with things and putting more $$$ in the upgrade....
Prefer Newegg, but using Amazon is fine also.
CPU
Intel Core i9-12900K - Core i9 12th Gen Alder Lake 16-Core (8P+8E) 3.2 GHz LGA 1700 125W Intel UHD Graphics 770 Desktop Processor - BX8071512900K
MOBO
GIGABYTE Z690 AORUS PRO LGA 1700 Intel Z690 ATX Motherboard with DDR5, Quad M.2, PCIe 5.0, USB 3.2 Gen2X2 Type-C, WiFi 6, 2.5GbE LAN
CPU COOLER
CORSAIR - iCUE H100i ELITE LCD Display Liquid CPU Cooler 120mm Fans + 240mm Radiator Liquid Cooling System + Custom IPS LCD Screen
MEMORY
G.SKILL Trident Z5 RGB Series 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model F5-6000J4040F16GX2-TZ5RS
GPU
GIGABYTE EAGLE OC GeForce RTX 4080 16GB GDDR6X PCI Express 4.0 x16 ATX Video Card GV-N4080EAGLE OC-16GD
STORAGE
Crucial P3 4TB PCIe 3.0 3D NAND NVMe M.2 SSD, up to 3500MB/s - CT4000P3SSD8
KEEPING FROM OLD BUILD
  1. ASUS Republic of Gamers Swift PG348Q 34" 21:9 Curved Ultra-Wide G-Sync IPS Monitor
  2. Lian Li Full Tower Case
  3. Sound Blaster AE-5 Plus Sound Card
  4. Corsair HX Series, HX1000, 1000 Watt, Fully Modular Power Supply, 80+ Platinum Certified,
Let me know your thoughts on these choices.
-I may have overdone the CPU and GPU choices. Should I bump down the CPU a notch or two along with GPU to something like the 3080 ?
Again, thanks for your help and time.
Good question -_-
The I9-12900K was listed on some suggested "higher" end builds, so I was trying to put more future proof in the build going to it and bumping up the 3080 to the 4080.
The reality is that the CPU you pick beyond a 12700k or a 13600k will be mostly useless because all you are getting for 100s more is 1-5% fps and more cores, which will be useless for most game in the foreseeable future. The 13000 series intel CPUs will pretty much all get you more fps stock than a 12900k because the single threaded improvement makes up for a lot with the increased clock rates of the older higher end CPUs. Personally I would get a 13600k or a 13700k for a build right now but leaning towards the 13600k for people that don't intend to do any productivity tasks.
Reactions: Lafong
Elusive Ruse
Commendable
Nov 17, 2022
368
480
1,220
I'm more inclined towards AMD, but 13600K is a great CPU - better than AMD's similarly priced offerings if you also use your PC for multithreaded work i.e. productivity/professional. For your SSD I'd say a 2TB Samsung 980 Pro is the sweet spot. You already have a great PSU IMO so keep that. RAM go ahead with the Corsair Vengeance, don't pay the ASUS premium and consider staying away from the vanilla 3080; either go with 7900XTX if you can find a partner model at MSRP or 6950XT.
EDIT: Before I forget, if this is your cooler it apparently is not compatible with LGA1700, my rec is any of the Arctic LF II variants.
Nytmare
134
9
18,685
Okay, trying things again tweaking things around.
If I can again get a review of the choices with regard to compatibility and individual component choices.
Budget around $2500
Sites: Newegg but Amazon is fine
Much appreciated any help provided !
CPU
Intel Core i7-13700K - Core i7 13th Gen Raptor Lake 16-Core (8P+8E) P-core Base Frequency: 3.4 GHz E-core Base Frequency: 2.5 GHz LGA 1700 125W Intel UHD Graphics 770 Desktop Processor - BX8071513700K
https://www.newegg.com/intel-core-i7-13700k-core-i7-13th-gen/p/N82E16819118414?Item=N82E16819118414
CPU COOLER
Corsair Hydro Series, iCUE H100i ELITE CAPELLIX, 240mm Radiator, Dual ML120 RGB PWM Fans, Powerful iCUE Software, Liquid CPU Cooler LGA 1700 Compatible
https://www.newegg.com/corsair-liqu...pellix/p/N82E16835181201?Item=N82E16835181201
MOBO
https://www.newegg.com/asus-rog-strix-z790-f-gaming-wifi/p/N82E16813119599?Item=N82E16813119599
MEMORY
G.SKILL Trident Z5 RGB Series 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model F5-6000J3636F16GX2-TZ5RS
https://www.newegg.com/g-skill-32gb-288-pin-ddr5-sdram/p/N82E16820374352?Item=N82E16820374352
SOLID STATE STORAGE
SAMSUNG 990 PRO M.2 2280 2TB PCI-Express Gen 4.0 x4, NVMe 2.0 V7 V-NAND 3bit MLC Internal Solid State Drive (SSD) MZ-V9P2T0B/AM
https://www.newegg.com/samsung-2tb-990-pro/p/N82E16820147861?Item=N82E16820147861
  2. • In-Plane Switching (IPS) Technology
  3. Lian Li Full Tower Case
  4. Sound Blaster AE-5 Plus Sound Card
  5. Corsair HX Series, HX1000, 1000 Watt, Fully Modular Power Supply, 80+ Platinum Certified,
That motherboard is back ordered at New Egg. And it is 420 dollars. Could be an excellent product, but I'm wondering if you have seen any reviews? Do you need all of those features...PCIe 5.0; four M.2 ports, etc? Your chosen M.2 drive is not PCIe 5.0. Just wondering if you could step down a bit on the motherboard and spend the saved money elsewhere?
I'd be sure to drill down on that liquid cooler for reviews and others' experience.
Reactions: Why_Me
Hello all !
CPU:
CPU COOLER:
MOBO:
GPU:
MEMORY:
-OR-
SOLID STATE DRIVE:
-OR-
HARD DRIVE:
? not sure
WD 1 TB Hard Drive
If it hasn't already been asked, what exact model of Lian Li case do you have?
Heya,
The case is somewhat getting old, but build quality is quite nice and very roomy for all the parts.
The case is legacy and is not being built anymore.
LIAN LI PC-A7110B Black Aluminum ATX Full Tower Computer Case
LIAN LI PC-A7110B Black Computer Case - Newegg.com
That's a solid case for sure ^^ but like most of the older Lian Li's it doesn't have good airflow. One last question ... do you prefer RGB or no RGB?
Intel is due to release their locked cpu's along with the B760 boards January 3rd.
https://www.newegg.com/p/2AM-000Z-000A7
LIAN LI LANCOOL 216 X Black Computer Case $99.90
https://www.newegg.com/corsair-rmx-series-rm1000x-cp-9020201-na-1000w/p/N82E16817139273
CORSAIR RMx Series (2021) RM1000x 1000W 80+Gold Modular Power Supply $189.99
B760 DDR5 Motherboard $160 - $200 if I had to guess. Here's an example of one of those boards.
https://www.techpowerup.com/302215/msis-b760-mag-tomahawk-pictured-ahead-of-official-launch
Intel Core i7 13700F Processor $350 if I had to guess.
https://www.amazon.com/dp/B07WNJCVNW
ARCTIC Liquid Freezer II 360 AIO $130.99
https://www.newegg.com/g-skill-32gb/p/N82E16820374430
G.SKILL Ripjaws S5 Series DDR5 6000 32GB (2x16GB) CL36 $149.99
https://www.bhphotovideo.com/c/product/1614794-REG/pny_technologies_m280cs2130_2tb_rb_2tb_cs2130_nvme_m_2.html
PNY CS2130 2TB M.2 PCIe NVMe Gen 3 x4 SSD $139.99
https://www.bestbuy.com/site/gigabyte-nvidia-geforce-rtx-4080-eagle-16gb-gddr6x-pci-express-4-0-graphics-card-black/6525662.p?skuId=6525662
GIGABYTE GeForce RTX 4080 Eagle 16GB Graphics Card $1,199.99
Total: $2460.65
RGB version of that build up above. Swap out the Case, AIO and RAM with these.
https://www.newegg.com/p/2AM-000Z-000A8
LIAN LI LANCOOL 216RX ARGB Mid Tower Computer Case $109.99
https://www.amazon.com/dp/B08WRWNNZ9
ARCTIC Liquid Freezer II 360 A-RGB AIO $159.99
https://www.newegg.com/g-skill-32gb-288-pin-ddr5-sdram/p/N82E16820374351
G.SKILL Trident Z5 RGB Series DDR5 6000 32GB (2x16GB) CL36 $179.99
Total: $2529.94
https://videocardz.com/newz/intel-t...pus-and-b760-motherboards-on-january-3rd-2023
https://lian-li.com/product/lancool-216/
https://www.tomshardware.com/reviews/lian-li-lancool-216-review
View: https://www.youtube.com/watch?v=5nZhqlO8-ek
View: https://www.youtube.com/watch?v=6_w0NbB84P0
View: https://www.youtube.com/watch?v=ykbhuv6yLBc&t=102s
Nytmare
134
9
18,685
1. Stupid question, but what is "RGB"?
2. What is the advantage of the B760 chipset over the Z790?
3. On the existing Lian Li case I have, I did add some extra internal fans along the with new side panel with a 250 mm fan. So the airflow is better than what was present in the stock set up.
THX in advance.
Ar558
Proper
Dec 13, 2022
228
93
160
THX in advance.
RGB is the coloured lights that appeal to the young people
The B760 is a lower tier so it's slightly less capable but should be at least £/$50 cheaper.
I think it stand for red, green, blue? Flashing lights if you like that.
B760 would lack SOME features not found on Z790. It's up to you to decide if the features it lacks are important for your specific purposes. Most people wouldn't need those extra features. Look at the specification sheet for any motherboard you are considering to examine the features.
It's no accident it isn't Z760 and B790. Some people figure 790 of anything must be better than 760. The marketing department knows that and names the chipsets accordingly to maximize revenue.
