I'm new to the whole PC world. This build was created this weekend: http://pcpartpicker.com/p/4GCXFT
I've had trouble running games that are not even graphically intensive and the graphics card was said to run modern games with no problem, so I thought maybe it was the power supply. But now I think its just that the monitor is VGA only. I have a VGA to VGA cable so I think my computer has only been using Intel's integrated HD graphics instead. Will a VGA to DVI cable or converter fix this problem? I have a 21.5" LCD monitor 1920x1080 60hz, not sure if this matters. Also if the cable or converter does work, will quality be noticeably sacrificed? Thanks for your time and help.
