** New Build ** i7 - Need your help building.
antekz
11
I need the best build for the best price of course. I will be using a 24" Lcd Acer monitor. This system will be used for gaming, picture editing, little video editing and ect.
I need your help from top to bottom. My Range is $1500 - $2000 USD. Lower the better of course.
All help will be appreciated. Thanks!
board - 329
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128361
cpu - 295
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
RAM - 246
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227375
case/psu combo - 360
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
Vido card - 400
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102768
HD - 90
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136283
combo drive - 23
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106100
dvd burner - 25
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
Don't know if you need an OS or not, but if you do, you can pick on of your choice. I would probably go with whatever you can get your hands on cheap for now, then switch to windows 7 when it comes out. Total of this system is $1768, so it leaves you well within your budget. You could add another HD for more space if you like, or add another one and run RAID 1 for data security. There is some room to play...
If you wanted to spend the money, you could upgrade to the i7 940. I don't know if it's worth the extra, but you would still be close to budget. If you have any sensitive data, you should probably buy the extra HD and run a RAID array that provides a mirror or parity backup. This will protect against a HD failure and complete data loss. One other suggestion would be, if you don't need a lot of HD space, buy the 300Gb velociraptors instead of the cavair black. It is more expensive for less storage, but they are faster. It all depends on what you want to get out of it.
sheppyb
19
You can save a few bucks and go with ...
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case ($80)
SILVERSTONE ST70F 700W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS - the modular design is nice for case clean-up and airflow improvement ($125)
GIGABYTE GA-EX58-UD4P LGA 1366 Intel X58 ATX Intel Motherboard ($260)
Doing so will bring you down closer to $1500.
I also second using a RAID (1 mirror) for data security.
JoeJITSU
94
Question on the RAID setup. I have a new computer that is ready to have the OS set. Can I add the extra hard drive in a week and use my machine today?
This build includes two gtx 285's running in SLI. Decent aftermarket HS will allow you to overclock it. Case has plenty of room, and great airflow.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160 $169.99
COOLER MASTER HAF 932 RC-932-KKN1-GP Black Steel ATX Full Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256028 $299.99
SILVERSTONE OP1200 1200W ATX 12V 2.3 & EPS 12V SLI Ready CrossFire Ready Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128374 $259.99 ($239.99 after $20.00 Mail-In Rebate) Free Shipping*
GIGABYTE GA-EX58-UD4P LGA 1366 Intel X58 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202 $288.99 Free Shipping*
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185093 $39.99
Scythe SCMG-2000 120mm Sleeve CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225 $109.99 Free Shipping*
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319 $79.99 Free Shipping*
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152 $24.99 Free Shipping*
LG Black 22X (CAV) DVD+R 8X DVD+RW 16X DVD+R DL 22X (CAV) DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD±R DVD Burner - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130442 $339.99 ($319.99 after $20.00 Mail-In Rebate) Free Shipping*
EVGA 01G-P3-1281-AR GeForce GTX 285 1GB 512-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
Total: $1953.90
vasilli_65
37
Going of topic a bit here but i have been looking for pc parts for a number of months, i just noticed that that rig is very decent and for a good price. I was looking at a similar build but i live in Australia and the prices are much higher.
If i remove one of the 285 nad replace the ram with this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227381 $139.99
OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory
and the Motherboard with this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188039 $299.99
EVGA 132-BL-E758-A1 LGA 1366 Intel X58 ATX Intel Motherboard
The total price now comes to: $1673 USD or equal to $2586 AUD but i am unable to get such a god price in AUS is there anyway i cloud get newegg to ship to Aus
foolycooly
702
