New Build - Need Help
TilltAcide
24
Hey, Just going to get to the poing
New build: Red And Black theme, 650 budget
CPU: 3.7 ghz stock clock min, 6 core preferred 4 min, TEAM RED
CPU Cooler: Going to overclock it as much as possable so probabbly need one of these.
GPU: 4gb vram min, probably a gtx 960/950
PSU: Enough to power the build easily, MODULAR REQIRED
Case: No window, Red led fans preffered.
Windows: 7 or newer, cheapest i can get
Keyboard/Mouse: The CM Storm Striker red led bundle will do me fine
DVD drive: I really do need this, just need to beable to write and read cds and dvds, asus preferred
Memory: 8gb min, fastest budget allows
Headset: Logitech G230
Storage: 1tb min, Must be western Digital
MOBO: Asus preferred
Any thing else important i frogot add it but keep it in the budget, Thanks for any help!
Okay, why do you need a 6 core CPU? More cores is not better. Most tasks are single if not dual core. Most things do not benefit from 6 cores so anything above 4 unless doing a very specific task is a waste. You want good single core performance like an intel i5 6600k quad core or an i3 dual core
Im going to do some editing and need the cores. and i want amd not intell
