new build, onboard graphics problem
leony80
Hi,
I've just built:
Gigabyte B450M DS3H
Ryzen 2600x
Corsair LPX Vengence (CMK8GX4M1A2666C16) 8GB
Cooler Master CX600
No video card
Crucial MX500 SSD
I power up the system, the LED light on the board comes on (Orange), CPU and system fan powers but there is no video from HDMI (with HDMI Cable) or DVI (used DVI to HDMI converter for this)
The 24 ATX connector is not fully latched in, there is an issue with Cooler Master PSUs in this respect I suppose. But it is very tight.
I don't know what the problem might be or how I can diagnose the issue as I do not have spare parts to test.
Can you please help?
Hi
Thanks for the answer. Are you sure on this?
Specs
I am looking at the specs above which states:
Onboard Graphics
Integrated Graphics Processor:
1 x DVI-D port, supporting a maximum resolution of 1920x1200@60 Hz
* The DVI-D port does not support D-Sub connection by adapter.
1 x HDMI port, supporting a maximum resolution of 4096x2160@60 Hz(Note)
* Support for HDMI 2.0 version and HDCP 2.2.(Note)
Why would they put Hdmi and Dvi if there was no onboard graphics?
