Question New build, power led on but no post
blackdevilmt
144
Mobo and CPU second hand from same seller. Told it was working fine.
Graphic card also fine
Troubleshooting
Cleared CMOS
Painful but tried everything on a bench
Only one stick installed
Checked seating of CPU ok.
Cable checks all good from CPU to mobo
Issue
Won't post at all
Strange that graphic card fans try to spin and then come to a halt.
Generally I would say either CPU fried but I don't think so.
Video on Google drive.
https://photos.app.goo.gl/5eqaqDyWSp1UBPy47
Further troubleshooting
Removed gpu
Removed nvme
PSU fans starts and then stops after 10 seconds
I see no sign of anything burnt on motherboard.
So strange never had this issue
Ralston18
Update your post to include full system hardware specs and OS information.
Include PSU: make, model, wattage, age, condition (original, new, refurbished, used)?
Disk drive(s): make, model, capacity, how full?
Will the system boot via Safe Mode?
Try a new CMOS battery as a matter of elimination.
blackdevilmt
144
PSU : re Corsair rm850w new rest off eBay as I just need a pc for light gaming and stuff. Just to save money 😄
16gb X2 adata 3800mhz
Mobo Asus tuf z370 pro gaming
CPU 8700k
Didn't try safe mode as usb ports can't get them to work.
I will get a cr2032 batt tomorrow see how that goes.
blackdevilmt
144
I don't think a new CMOS battery should be the issue. I can't get It to post.
This problem is just eating me alive. Never had anything of this sort.
Ralston18
Is there any warranty on the motherboard and CPU? Seller?
Does the following link provide the applicable User Manual?
https://dlcdnets.asus.com/pub/ASUS/mb/LGA1151/TUF_Z370-PRO_GAMING/E13395_TUF_Z370-PRO_GAMING_UM_WEB.pdf
[Do verify that I found the applicable manual.]
Review the full manual.
Look at the jumpers per Page 1-10, 11.
The the LED's starting on Page 1-12.
Next, take a closer look at details starting on Page 2-17 and then into Section 3.0 thereafter.
You may discover something not as it should be.
