Hello,
I have just put together a new pc (using some old parts) and it just won't start. The new build consists of a motherboard + memory + cpu and the remains from my old pc: sata drive, psu and dvd drives etc.
I was wondering if the reason the PC won't start is because the power supply is too weak. It says it's a 450 watt. I was told in the store that it was probably ok to runmy new gear on about 350w - 400w although the manual for the mobo says 5oow.
When I plugin it in and switch it on at the back nothing happens and when I switch it on at the front the fans pop on for a second and then off.
My mobo: Gigabyte h55-ud3h with core i5 661
Any help would be appreciated. Thanks.
