Hello,
I had built a new PC and when I turned it on the screen said,
"CPU or Memory Changed ! ! ! Please enter setup to configure your system.
Press F1 to run system.
Press F2 to load default values and continue.
I meant to press F1 but (I don't know how but I) pressed F2 on accident. Is there any way to go back to that menu so that I can press F1 instead? I tried to figure it out but I couldn't because I am very new to building PCs.
Forgive me if this is simpler than I think it is, I'm not very experienced in PC building.
Thank you in advance.
EDIT: When I pressed F2 it said,
"Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key"
UPDATE: I fixed it. It was just ready to install the OS. There was no problem but thanks for the help anyways.
