New Build Problems
retzman22
33
Just booted computer for first time. Computer turns on have fans working. power to gpu,mobo, disk tray works. After about 30 seconds computer shuts off and turns self back on. have no display to monitor. Any clues? I can post my build list if needed.
probably not, but having your monitor plugged in to the gpu before installing drivers may keep you from getting a picture to figure out more about the issue. Unless there is no igpu, where the motherboard uses whatever gpu is in as default.
If none of these ideas have helped, you may have a defective motherboard that needs RMA.
I have power to both chassis fans, power to mobo and gpu. HDD has both power and sata plugged in. Is there a way to verify hdd getting power? Both RAM full locked in. CPU fan is on.
how would I tell?
It's a 4 or 8 pin plug on the motherboard that should be connected to the psu during the build.
I have an 8 and 24 pin connected to MOBO.
