Hello,
I am doing a new build for my girlfriend. We had some help over at PcPartPicker forums with it and I am quite happy with few changes recommended but now just wanted a second opinion and a double check on a compatibility issue in the build. We already have a 1070 GPU so its not on the parts list.
https://au.pcpartpicker.com/user/Narttu/saved/MBFbXL
The comparability issue reads - "The motherboard M.2 slot #1 shares bandwidth with a SATA 6.0 Gb/s port. When the M.2 slot is populated, one SATA 6.0 Gb/s port is disabled." I don't think this is an issue though is it? The only other SATA port ill be using is my old HDD. Essentially we have 5 Sata ports and will be using two. Correct?
Also, in regards to cooling: Would it be worth it to purchase another chassis fan? I think this case only comes with two. Should I get another for the front? Or maybe one exhausting out the top?
I asked these questions over at PcPartPicker forum and all I got was someone linking me to a MiniATX motherboard with no explanation. Not sure why? =(
