New build questions - (psu / future proof / inconsistency check / bottleneck / resale of old parts / ram upgrade)
Imadiveyourtower
Another Summer another upgrade!! (and I'm single so like... no spending money on any girls but my mama)
I'm SUPER excited for this overhaul upgrade, initially I just wanted to upgrade my cpu but then, ya know.... now the only thing I'm keeping now is my case and RAM and some of the older storage.
Anyway...
This is my build so far: https://pcpartpicker.com/user/Enander/saved/#view=9M2tJx
All my questions are briefly mentioned in the description:
- I know that my psu isn't great. I want to be able to future proof my pc by having potential to run SLI in the future, if I so desire. Projected wattage so far is 484 and I imagine that's at full load. After some research, it seems like any psu gold and above rated is good enough for my build, but I am unsure about how much wattage I'll need to future proof it for potential SLI. I also plan on overclocking to 4.8 ghz I imagine, so maybe that's a factor that isn't taken into consideration on pcpartpicker.
- I am just curious as to where my pc might bottleneck / what your opinions are on what the weakest parts of the system might be.
-Now that I am revamping my system, I have a ton of good pc parts, how should I go about with selling them?
-I only have 16 gb of ram but its pretty high quality ram, right? Do I need more? If I get another 16gb, does it have to be the same type?
Any and all help is GREATLY appreciated! Thanks for taking the time to help!
PuperHacker
992
11
5,415
195
- For a gtx1080ti sli along with an overlocked i7 8700k, I wouldn't go below 650w. Your PSU is fine in wattage, but I suggest a corsair RM750 instead.
- I don't think anything existing on the market would be bottlenecked by an i7 8700k. Allow me to say that there are no noticeable bottlenecks.
- Why sell the rest of your parts? You will have a hard time finding something better in the market!
- 16GB and particularly this type should last for a coouple more years, 32gb is expensive, yet not overkill for your setup.
logainofhades
Waste of money, if you are going to use that junk PSU. Change it to an Evga 750w G2/G3. It isn't much more, and your system will thank you. 1080p with a 1080ti graphics card? That card should be paired with at least a 1440p monitor. You can get a board with wifi, for less. Games really don't take advantage of the speed of the 970 pro, which I am assuming what this build is geared for. The 970evo is more than enough for this, and even that is overkill.
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor ($347.00 @ SuperBiiz)
CPU Cooler: Corsair - H115i PRO 55.4 CFM Liquid CPU Cooler ($139.99 @ Amazon)
Motherboard: Asus - ROG STRIX Z370-E GAMING ATX LGA1151 Motherboard ($190.98 @ Newegg)
Memory: G.Skill - Trident Z 16GB (2 x 8GB) DDR4-3200 Memory ($174.99 @ Newegg Business)
Storage: Samsung - 850 EVO-Series 250GB 2.5" Solid State Drive ($99.99 @ Samsung)
Storage: Samsung - 970 Evo 1.0TB M.2-2280 Solid State Drive ($396.01 @ Amazon)
Storage: Western Digital - Caviar Green 1TB 3.5" 5400RPM Internal Hard Drive ($63.99 @ Amazon)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING OC Video Card ($829.99 @ Amazon)
Case: NZXT - S340 (Black) ATX Mid Tower Case ($59.99 @ SuperBiiz)
Power Supply: EVGA - SuperNOVA G3 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($83.98 @ Newegg Business)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($99.99 @ Adorama)
Case Fan: Corsair - Air Series AF140 Quiet Edition 67.8 CFM 140mm Fan ($19.80 @ OutletPC)
Monitor: Asus - PB277Q 27.0" 2560x1440 75Hz Monitor ($283.92 @ Amazon)
Keyboard: Corsair - K70 LUX Wired Gaming Keyboard ($99.89 @ OutletPC)
Mouse: Razer - DeathAdder Elite Wired Optical Mouse ($69.79 @ OutletPC)
Headphones: SteelSeries - Arctis 7 Headset ($149.99 @ Amazon)
Total: $3110.29
Generated by PCPartPicker 2018-06-08 17:28 EDT-0400
Imadiveyourtower
So you don't feel like I would bottleneck with wattage on a 750 if I ended up upgrading to SLI?
I also meant that I am reselling my old parts, I was AMD ryzen 1700 and my 1070 and a bunch of older hardware that ill be taking out. So where is the best place to sell those?
Why that particular psu?
Imadiveyourtower
Why that particular psu? Why exactly would my system thank me? Do you have any ideas for where I can go to sell all my old parts?
Imadiveyourtower
Why that particular psu??
Don't have to choose THAT specific PSU, but it is high quality.
Could also go with:
Corsair RMX 750W
Seasonic Focus Plus 750W
Or
Seasonic Prime 750W.... Gold, Platinum, or Titanium (Considered to be the best PSU on the market) for the high end.
I wouldn't even consider anything but the above recommendations for that system.
Imadiveyourtower
Thanks for the good info. Last thing, any idea on where I could resale my old gpu,cpu,psu, all the u's
logainofhades
High quality, great price, and you don't have to worry about components dying prematurely due to a low quality power supply, or out right killing them when it dies. The CX750m is simply not that great of a PSU, whether it be the 1st gen or 2nd gen version of it. The 10yr warranty, on the 750 G3, is nice too.
Imadiveyourtower
Thanks for all the responses. I guess Ill try to ebay my old parts and I ended up going with the
Corsair RMX 850W!
Thanks all, case closed! BADUMTSHH
