New Build - Unsure of a few things and would appreciate help
tarshm
78
Thanks for taking the time to read and hopefully help me out
Approximate Purchase Date: Within a month max, but sooner the better.
Budget Range: $1400.00AUD but flexible if its worth it.
System Usage from Most to Least Important: Gaming (anything and everything, BF3 to give you an idea), productivity, internet.
Parts Not Required: Speakers. I have a 1440x900 screen but i plan using it as a secondary screen in a dual screen set up.
Preferred Website(s) for Parts: http://www.msy.com.au/default.jsp?category=21&page=2 (http://msy.com.au/) or www.umart.com.au/ MSY is better priced in my experience
Country of Origin: Australia
Parts Preferences: Not fussed
Overclocking: maybe
SLI or Crossfire: Possibly in the future but i generally prefer a single powerful card than 2 average cards
Monitor Resolution:
as per above i have a 1440x900 and based on my research thus far 1920x1080 seems to be the likely candidate for my primary screen
Additional Comments:
see below:
Ive done some research and have come up with a preliminary build (or part of), ignore the fact that some of the stuff is out of stock on the website.
Seagate 3.5" Barracuda 1TB ST31000524AS SATA3 7200RPM 32MB HDD
http://www.msy.com.au/product.jsp?productId=7386
Intel Core i5-2500K 3.3Ghz 1155pin Boxed CPU
http://www.msy.com.au/product.jsp?productId=7581
Antec 300 Three-Hundard Gaming Tower without PSU
http://www.msy.com.au/product.jsp?productId=878
Microsoft MS Windows 7 Home Premium 64bit OEM
http://www.msy.com.au/product.jsp?productId=5821
G.Skill Ripjaws X F3-10666CL9D-8GBXL 8G Kit(4Gx2) DDR3 1333
http://www.msy.com.au/product.jsp?productId=7261
2GB Powercolor 6970 PCI-E VGA Card
http://www.msy.com.au/product.jsp?productId=7168
Samsung SATA 22x Black DVD RW - 1 Year Warranty
http://www.msy.com.au/product.jsp?productId=5580
Gigabyte Wireless Desktop GK-KM7600 Multimedia (K/B+Mouse)
http://www.msy.com.au/product.jsp?productId=8243
As is obvious im still unsure as to what PSU, MOBO and Monitor (something around 23-24inch and $170.00) to for and im on the fence about the GPU as well.
So please review, criticize, and let me know what you think.
EDIT: I plan to only game on the primary screen and not "stretch" it across both
Antec High Current Gamer Series HCG-900 900W ATX12V v2.3 / EPS12V v2.91 SLI Certified CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply
ASUS Maximus IV Gene-Z LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
ASUS VS248H-P Black 24" 2ms HDMI LED Backlight Widescreen LCD Monitor 250 cd/m2 ASCR 50,000,000:1
EVGA 025-P3-1579-AR GeForce GTX 570 (Fermi) HD 2560MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
I know the MB might be a little on the expensive side but everything plugs into it and I guess I just don't believe in going the cheap route on it. The power supply will do you for now and for sli/crossfire in the future.
tarshm
78
Thanks for the response, heres my thoughts.
- PSU > I can agree with you on that although suppose i dont intend on going xfire/SLIing GPUs could i go for something else?
- MOBO > I like you dont beleive in cheaping out on anything however it seems a little excessive, is there something a bit more mid range? Also consider the comments for PSU above.
- Monitor > Seems ok although i dont have my knowledge in that area
- GPU > not sure where you got that card from? Did you see the sites i listed? those cards only come in 1280MB sizes which is why i went for the 6970 which has 2GB and has comparable performance and price to my understanding
thanks.
