I've got a new computer with an Asus P5Q pro mobo and a cooler master case that has 2 usb ports on the top with a few other connections. I was pretty sure I had everything hooked up right but when I was setting it up and had to use some files to get my computer to recognize my hdd I used a jump drive. It then said something along the lines that it couldn't recognize it and now it wont work on any computer. I kind of wrote it off as I was excited to get my computer going, I ended up hooking up my external hdd to the same ports and now neither of my computers will recognize it. The jump drive is not a big deal but my external has a ton of data on it and I would very much like it to work. Messing around with it I put my jump drive back in for a little while and it started to really overheat leading me to think it's a power problem. The only thing I wasn't really sure on when putting this build together was two 6 pin connectors on the upper left of the mobo, one of them had a cover but in the asus manual it said something like be sure to remove the plugs on theses connectors before connecting them so I did just that. Anyone have any advice, this is my first build but I'm fairly good with computers.
